Results 1 to 40 of 42
    Oct 16 2008
    South Florida - Ft Lauderdale
    Re: Can't figure it out!!
    Woaw......
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    From a quick search about the net, everything is pointing to the dreaded camshaft failure Usually found with other codes though?
    Pull that pump again and have a look around....
    http://www.audizine.com/forum/showthread.php?t=295208
    http://www.awe-tuning.com/media/pdf/...FP_Upgrade.pdf
    Hope others here have better news,
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Oct 16 2008
    Quote Originally Posted by RVT View Post
    Vince
    Agree Vince but my problem is only happening at iddle, when the fuel supply is minimum. Going to pull the pump again this WE but I doubt it's the root cause.
    phil
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    any fuel leaks at the fuel filter area?
    Oct 16 2008
    Quote Originally Posted by illegitimus View Post
    Nope, dry like a bone
    Phil
