Need help. I have a 2004 A4 1.T Quattro. I have replaced breather hose, crankcase hose, and PVC. Cleaned MAF. Also, replaced valve cover gasket and spark plug ring gaskets (this was purchased as a set) due to oil leaking into spark plugs. I'm still throwing P0171 (system lean) and P0507 (idle higher than expected). When I pull the dipstick I get a strong sucking sound and the engine almost dies, but never actually does...just runs really rough and acts as if it will die. I tried pulling off the oil cap and I can't because of the strong suction created. What is causing this strong suction? I can't find any leaks, as I have gone thru the vacuum system and replaced cracks. The engine at start-up runs at 800 rpms...then after couple minutes jumps up to 1200. I have replaced spark plugs and they are gapped at .32 (everything is stock in this engine). I did replace the coils, but that did not help. I didn't expect new coils to help...just a gut feeling. When I drive the car it runs fine at high rpms. Before I replaced all hoses and PVC I was getting terrible gas mileage. At least now it's back to normal with the gas mileage, but I'm still getting the jump in RPM's at idle after a normal 800 rpm start-up.
Why would removing the dipstick while engine running make a loud sucking sound and why is it impossible to remove oil cap while engine running? Is this normal or do I still have a vacuum leak which is causing this?
Any advise or similar issues out there? Help much appreciated.
If I unplug the MAF sensor the engine starts to run rougher.
One last note. There is a hose coming from the manifold to the crankcase bleeder assembly. When I pinch that hose the engine actually runs smooth. I hear a sucking sound coming from the PCV, but when I pinch the hose the sucking sound from the PCV stops and the engine runs smooth. Any one have any ideas? Like I said, impossible to remove oil cap and strong sucking sound from the dipstick when I remove, while engine running.
