WOW...Guys I did it!!!!...
Thanks to your wonderful help....A big thank you to EVERY SINGLE ONE THAT REPLIED TO MY POST!!....
I will post some pictures and how I manage to do it, my next challenge is to buy a Multi-Function Steering, have it fitted and code it using the VagCom...
WARNING - IF YOU CANNOT FOLLOW INSTRUCTIONS OR NOT TECHNICALLY MINDED I WILL ADVICE YOU NOT TO ATTEMPT THIS BECAUSE YOU CAN SERIOUSLY MESS YOUR CAR UP AND IT WILL COST YOU THOUSANDS TO FIX
BEFORE VAGCOM SCREEN BELOW
[IMG]
[/IMG]
ITEM REQUIRED - LAPTOP (I used Windows XP, I am sure it will work with Windows 7 32 or 64 bit as well, I am not a fan of Vista), VAG COM USB DIAGNOSTIC CABLE 409.1 OBD2 II LEAD VAG-COM (VCDS-Lite works with XP, Vista, Windows 7 32/64 bit UK) I bought this cable from eBay UK for £7.98 and it comes with the VCDS Lite see link to eBay item i bought http://www.ebay.co.uk/itm/330399696070.
When I spoke to Audi they told me I cannot get this cable...hahaha!
PROCEDURE BELOW
NOTE - Your RNSE will be locked while in the option No-37 Nav or No-56 Radio
I got the code 7 in step 5 from this forum see link http://www.audi-sport.net/vb/new-a3-...ing-rns-e.html
1. Install cable driver 1st on the laptop.
2. Then install VCDS Lite software, it can be downloaded at this link http://www.ross-tech.com/vcds-lite/download/index.html and install it as well
3. Open VCDS Lite software you will be greeted with the main screen, click on the icon that says Select (Select Control Module)
4. You will get the 2nd screen with several tabs, the Common tab should be selected if it is not the default, select 37-Navigation or 56-Radio.
5. On the next screen 3 select the Recode-07 (My code was 0413111) (I changed it to 0413711 and click Do It) see the rest of the screen below.
6. Come out and you will see the bluetooth on the RNSE.
VagCom Cable I used is NOT Hex+k+Can, I believe there is some cars out there that might require a CANBUS enabled Cable
[IMG]
[/IMG]
[IMG]
[/IMG]
VAGCOM SCREEN PROCEDURE I USED BELOW
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
PAIRED WITH NOKIA X2 BELOW (O2)
[IMG]
[/IMG]
Phone Book also works
PAIRED WITH BLACKBERRY 9800 TOUCH BELOW (ORANGE)
[IMG]
[/IMG]
