Results 1 to 38 of 38
    May 09 2009
    Syracuse, NY
    Ripped CV boot: Replace Axle?
    I was finally to get under my car today and saw that my CV boot is ripped. I'm not sure how long it was ripped for, but it definitely had been leaking the grease.
    My question is this: Should I replace just the boot or should I just go with a whole new axle? And is it safe to drive on for another couple days so I can get the parts?
    Veteran Member Three Rings infinitigor's Avatar
    Jul 17 2008
    02' b6 1.8t
    Re: Ripped CV boot: Replace Axle?
    yea it should be safe to drive with it the way it is for a while, maybe grease it up a lil and duck tape it for a temporary fix. But id def recommend just getting a new axle, the work to repair it with a new boot would just be as costly as a new axle.
    revo//s4 front//sides//s4 rims//h&r//rs4 sway//b5 s4 brakes//rns-e
    Established Member Two Rings flashovermac's Avatar
    Apr 07 2009
    unless you do it yourself....
    http://www.audiworld.com/tech/wheel37.shtml
    May 09 2009
    Syracuse, NY
    Quote Originally Posted by infinitigor View Post
    Well the axle is about $130 and the boot repair kit is only about $30. I was just wondering if there was a good possibility that the CV joint would be damaged. If that's the case, then I would just get a new axle. And I do plan on doing it myself.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    Get the whole axle you can find them for pretty cheap and it's just easier to do. I just replaced mine about 5 days ago and I just di the whole axle.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    May 09 2009
    Syracuse, NY
    Quote Originally Posted by audiluxary View Post
    Got a source for a cheap axle? The cheapest I could find was ECS.
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by turbo_bootin View Post
    JHM Motorsports has them, good prices and great people too. Booth my axles are from them for like $100 +/- each. Much easier than doing the boot replacement mess (that grease gets everywhere). Good DIY on AudiWorld too.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Sep 26 2008
    Grand Rapids
    I replaced mine awhile back and got the axles from europartsdirect for something like $70 bucks a axle with free shipping.
    Speedtuning ECU-RSR Body Kit-2.5in Custom Exhaust-VDO Boost Gauge
    http://i10.photobucket.com/albums/a1...i5/AudiSig.jpg
    Jun 19 2008
    Coquitlam, BC
    Actually, the Audi CV joints are almost bulletproof and will take a huge amount of abuse. And that includes driving around for an extended period of time with a ripped boot.
    I've heard of shops with customers driving around with ripped boots for over a year with no issues, before boot was replaced.
    From personal experience, I had a ripped outer CV boot on my A4 for at least 6 months before I discovered it.
    Aftermarket boot kit ( German made. Good quality with grease and hardware ) cost me $17.94 wholesale. That's right...$17.94!!
    Pulled axle apart, cleaned CV with brake clean, greased and reassembled. CV joint was in absolutely PERFECT condition....despite the ripped boot. Absolutely no wear at all. ( Audi CV's are much better quality than VW CV's ). This was at 158,876 KM.
    Car now has 187,00+ KM and not a hint of noise from CV's.
    So from my experience, I would say....if the CV is not making noise and looks OK, service the joint and slap a new boot on it.
    PS: I'm sure that the OEM German Audi CV or half-shaft is going to be a lot better quality than an aftermarket CV or half-shaft.
    Jun 30 2008
    Erie, Pennsylvania
    ^^What He said.
    Quote Originally Posted by BlackBirdSR71 View Post
    Exactly. In our shop we always try to save the original axle, it is the best you can get. Just do the boot. The grease is messy, but after a few washes your hands will be kind of clean again.
    Off Topic: As a side note, this logic sort of applies to starters, alternators, and other parts too. Why chance it with an aftermarket/reman alternator for $$$ when your old one just needs $5 brushes?!?
    Jun 19 2008
    Coquitlam, BC
    ^^What He said.
    You're talkin' my kinda language
    Veteran Member Three Rings stack's Avatar
    Oct 27 2008
    E46 M3
    Queens NY
    Yea I got the same thing just that I have no boot..
    Its been like this for a while...
    I had no idea.
    I just greased it up a lot. And put a plastic bag over it. Works fine but its just temp.
    But honestly I don't think you need a new axle..
    If anything napa has an axles. Oem for 80 bucks. I bought one already
    Veteran Member Four Rings mholme's Avatar
    Jan 29 2007
    08 S4 00 S4
    MD
    I don't know if A4/S4 axles are similar enough, but I had a nightmare recently with aftermarket axles. I vote reboot the stock one.
    http://www.audizine.com/forum/showthread.php?t=302877 You can ignore the stuff about the transmission coming out, that was a seperate issue, but the aftermarket axle managed to destroy my passenger side flange.
    08 S4- Stock SOLD
    00 S4-APR 93 Piggies Custom True Dual exhaust AWE DTS ECS/Bilstein Coilovers 710N's Samco TBB Omori 52mm boost gauge SOLD
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    ^^^^^ If its not clicking when turning hard left or right then just get a new boot kit. Theres a reason why audi axles are 500+ dollars and the replacement axle is 100-200 bucks. There junk and Personally dont last half as long. Especially if you have big power upgrades they will snap!! Seen it numerous times.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    May 09 2009
    Syracuse, NY
    Thanks for the advice guys.
    Veteran Member Four Rings LateraLex's Avatar
    Jun 13 2005
    A4 1.8tQM 01
    the mean streets of Boston
    Boot kit will do it. Messy job though.
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    i just did a boot while my car was down for my motor build. 45 min job with the right tools and a buddy
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Nov 21 2007
    The Sticks
    I got mine from Raxles. I don't have the space anymore at my new home to actually work on the car so I just swapped the whole axle out and called it a day. If you have the time and place to do it then save yourself a couple bucks and get just the boot.
    2001.5 1.8t
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    I'm stg3 and run axles advanced auto carries, and have had zero issues.......for me after replacing a boot only to have to replace it again a year later(used OEM) the axle swap was nice, it has a lifetime warranty so if the boot rips again or the axle fails, freebie. I feel confident recommending this axle as a good alternative. There are tons of these threads floating around as well. Search is your friend for this type of application.
    Established Member Two Rings esee135's Avatar
    Jun 21 2008
    If the boot is broken and it still has grease (like mine), and you're not getting clicking sounds, you can just do the boot, so far I've gotton 20000km on that axle, no issues yet. The only thing to be worned about is if you have alot of salt in your area, like mine, and if no one ever replaced the spindle bolt, don't be surprised that you strip the hex head when you line up for the olympic squat to release the bolt. I ended up having to weld an extension nut to the spindle bolt, and using my impact to drive it out. PB Blaster everything prior to removal and anti-seize every nut and bolt you can when you reassemble.
    Oct 21 2009
    full time
    easton
    when my driver side ripped last winter i was lucky enough to have my father in the states. he is a old school porsche racer/tech and i asked him to prie them for me. imc in cali has oem axles for like 50 new. but if your going to drive with the boot rippedopen don't replace just the boot, even though its a small chance that something detrimental got in there if it did and you replace just the boot your going to feel like an ass if you drop cv guts all over the road. and who knows what else will get bombed if it does go. brake parts get costly quick
    Veteran Member Three Rings jsquillz22's Avatar
    Feb 22 2009
    b5 s4
    Chicago
    have done it like 4 times!!! super easy
    OEM+
    Who Cares?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by b5blazing View Post
    A proper reboot job does involve cleaning, inspecting and replacing of the internal washers and circlip. I hope no one just throws on a new boot and calls it a day.
    08 S4- Stock SOLD
    Feb 22 2009
    b5 s4
    Chicago
    Quote Originally Posted by mholme View Post
    yeaa i did that and actually cleaned every ball.... im pretty anal when it comes to clean balls
    OEM+
    Who Cares?
    Oct 25 2009
    Houston
    i believe o'reilys carry some rebuilt axle for cheap, like $50-60
    May 09 2009
    Syracuse, NY
    So I got a boot kit from Autozone. At first, they didn't want to include the grease for some reason and refused to give it to me.
    Now, I was re-reading the DIY and it said that the axle bolt "should always be replaced, never reused." Unfortunately, the shitty kit from Autozone didn't include the new bolt. Is it really that bad to reuse the bolt? I'm thinking my best bet is to try and get a new one from the dealer. Thoughts?
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    purems... i got 2 kits in my trunk, they got everything
    __________________
    Jan 29 2007
    08 S4 00 S4
    MD
    They are torque to yield bolts and intended to be used only once. If you reuse it, you run the risk of it not holding the specified torque and backing off. And they are quite expensive through the dealer, even world pac vendors.
    08 S4- Stock SOLD
    May 09 2009
    Syracuse, NY
    How expensive is "expensive"? I don't really have too much of a choice now, since I already bought the kit and I need to do it this weekend. Is there any other places that I might be able to get it local?
    Jan 29 2007
    08 S4 00 S4
    MD
    15-20 dollars each, depending on which source you use. My boot kits came with new bolts that I didn't use since I had already got new ones. Impex got them for me at cost since the bunked axles I bought from them didn't come with any. I'd offer them to you but they wouldn't get to you until Saturday at the earliest.
    08 S4- Stock SOLD
    May 09 2009
    Syracuse, NY
    $15. Damn. Thanks for the offer, but I need them by tomorrow.
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    how much is the cost for replace ?
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    Quote Originally Posted by s4killer View Post
    $69.99 at Advance
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Jul 27 2009
    wisconsin
    Quote Originally Posted by bw86 View Post
    $69.99 at Advance
    labor??
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Dec 06 2008
    2.0L 058
    LI
    labor??
    It's a DIY - pretty straight forward
    --> first start <--
    Jul 27 2009
    wisconsin
    i think i cand do my self so in a shop how much you think charge for this i have a audi s4 01
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    May 09 2009
    Syracuse, NY
    I don't know. Try calling around to get a quote.
    Jul 27 2009
    wisconsin
    Quote Originally Posted by blackbirdsr71 View Post
    actually, the audi cv joints are almost bulletproof and will take a huge amount of abuse. And that includes driving around for an extended period of time with a ripped boot.
    From personal experience, i had a ripped outer cv boot on my a4 for at least 6 months before i discovered it.
    Aftermarket boot kit ( german made. Good quality with grease and hardware ) cost me $17.94 wholesale. That's right...$17.94!!
    Pulled axle apart, cleaned cv with brake clean, greased and reassembled. Cv joint was in absolutely perfect condition....despite the ripped boot. Absolutely no wear at all. ( audi cv's are much better quality than vw cv's ). This was at 158,876 km.
    Car now has 187,00+ km and not a hint of noise from cv's.
    So from my experience, i would say....if the cv is not making noise and looks ok, service the joint and slap a new boot on it.
    Ps: I'm sure that the oem german audi cv or half-shaft is going to be a lot better quality than an aftermarket cv or half-shaft.
    oops i have two winter with a rippep boot
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
