Results 1 to 11 of 11
    Sep 24 2009
    usa
    Question Fault code: P0741
    OEM Brand: Volkswagen
    Definition
    Torque converter clutch circuit performance or
    stuck on
    Explanation
    Open or short circuit condition
    Probable cause
    1.- Poor electrical connection
    2.- Failed torque converter clutch solenoid
    3.- Blocked oil passage
    the cel usually turns on if i am at wot or if i am doing a hard turn and sometimes after turning it seems like the tcc isnt catching...? not too familiar with tiptronic. any ideas or suggestions? i searched for this code and someone suggested it might be running low on the tiptronic fluid? how would i go about filling that up?
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    Re: Fault code: P0741
    I have had this on my car for a long ass time, I am sure my TC needs replacing but that's like the least of my LONG list of overdue maintenance.
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Working in a dealership and seeing this on a constant basis with S4's and Allroads, it looks like you need a new torque converter.
    Sep 24 2009
    usa
    Unhappy Re: Fault code: P0741
    Quote Originally Posted by qwerty1601 View Post
    whats a rough estimate of the cost of repairs? and how big of an issue is this (ie-will my car stop running in a few months?)?
    Jun 08 2007
    I have no idea the TC by itsself for a better one is like 950 I believe, if you call Audi your looking at like 3 or 4 grand if I remember correctly.
    I have had this issue for a couple years if I recall and its been ok so far (knock on wood) I dont want to jinx myself ugh.
    Sep 24 2009
    usa
    Quote Originally Posted by TWiST View Post
    jeez.. i think ill take some of your luck for now... thanks.
    Mar 11 2007
    8V S3
    tri state
    I've been out of the business for a couple of years now, but IIRC the labor time is about 13-15 hours, and the parts were around $6-700 at that time.
    It can eventually completely fail and you'll get no acceleration. That's extreme, but the normal occurrence is slipping.
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    did you search man... there are HUGE threads about this ... the latest being roughly 3 wks ago
    and yes.. you need a new TC 99% of the time... 1% of the time it's a solenoid...
    a new TC (upgraded) from 517 will run you about $500-600
    labor will be at least a grand ...
    Lurker
    May 06 2009
    01S4, looking for a second
    indy
    Quote Originally Posted by mrpeterparker View Post
    DING!
    Peter, now hurry up and come to the chat like a big boy.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    lol .. on my way into the office
    Lurker
    Sep 24 2009
    usa
