Results 1 to 4 of 4
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    Weird Driver Window
    so my driver side window acts really funny. use to be only when it was cold out but now it does it all the time. when i press the button to roll it up it starts to go and then it will slow to a stop. i then have to pull up on the window toward the back of the car. i can feel the window come up as if it is off a track or something but once i pull up it will continue the rest of the way. im not sure that made any sense at all but anyone have this issue? it wasnt a big deal at first but its just one of those things that really GRINDS MY GEARS haha
    Registered Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: Weird Driver Window
    lube your window tracks really good with a lithium grease..
    Gcc's blacksheep
    Established Member Two Rings 02wrangler's Avatar
    Jul 06 2009
    98.5 a4 1.8TQ
    Sacramento, CA
    Pull your door panel and clean the track, see if it gets better. If not then you need to pull the motor and run the regulator manually, its easier if its done out of the car but pulling the window up and down should tell you if its messed up.
    While you've got it out hook the motor back up to power and run the switch up and down. Whatever doesn't run smoothly needs to be replaced.
    Jun 10 2009
    Denver CO
    awesome i will take the door panel off and take a look this weekend. thanks for the quick responses! i hope i just need to grease the track
