Results 1 to 13 of 13
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    bt 3" boost tester?
    alright i know there are a ton of people on here with 3 inch inlets so lets see your DIY boost leak testers. Also a quick description of your method of testing that works best for you would rock too.
    ::2002 S6
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: bt 3" boost tester?
    just go to home depot buy some 2.75" pvc pipe, and a pvc endcap. Then run over to your local auto parts store and pick up a tire valve stem, drill out the end cap and place the valve stem in it...and what you have there is a boost leak tester for under $10. All you need is a compressor and 15-20psi of pressure and you can test your car
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    thanks dude, really appreciate it.
    ::2002 S6
    Oct 28 2006
    Quote Originally Posted by TQMB5 View Post
    no problem i'll try to find pics of the one I made and post it up so it'll give you and idea on what its gonna look like
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    Where do you find the Smoke? I know some places use smoke to help find boost leaks and
    vacuum leaks. I wasn't sure if it was "Special" Smoke.
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Senior Member Two Rings slideitsidewayz's Avatar
    Jun 30 2008
    1998 Audi A4 1.8tqm gt2871r
    North Jersey
    I have a pretty good one i made with a rubber plumbing end cap...its 3" i think...came with a hose clamp and just tightened it down til it fit...cost me like $3.75...then i punched a hole in the center with a screw driver and picked up a tire stem and put it in the hole...very legit..ill take a pic of it for you tomorrow bro.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by AudiRacerS4 View Post
    Just need the end cap, really dont need the actual pipe. The cap should have enough lip to use a hose clamp on. I did the same thing but with one that is large enough for my 4" inlet.
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Tire Stem, did you glue it down or what?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 28 2006
    Quote Originally Posted by biketsai View Post
    yup i gorilla glued the shit out of it lol
    Jun 21 2009
    Topeka, KS
    You don't need to tire stems are designed not to leak when pressure is applied to the back side of them. I'll bring mine with me when we meet up later so you can see what I did. I went fancy and installed a Air pressure gauge on it so I could load it up with pressure and leave it sit for a while and see if any pressure is lost.
    To test mine i used what ever size was 2.5'' for the outer diameter and then a 2" pipe plug. Pushed it up to 25PSI and then sprayed the connections with soapy water (still had a bottle of it left over from doing my tint). Sense the pressure was all going out not in there was no issue of getting moister in the pipes.
    Jun 30 2008
    North Jersey
    nah man, it was a 2 piece stem...its legit...ill post some pics later of it
    Jun 30 2008
    North Jersey
    Here is a pic or 2...sorry for the crap quaility
    I find it good to use a tire stem because if you're by your self and have a crap compressor, you can pressurize the engine and listen for any leaks or anything. I like it tho...good investment
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    thanks, i used that in mine to but with more parts and didnt think to use a tire stem. Will definitely be doing this tomorrow. What turbo do you have?
    ::2002 S6
