Results 1 to 3 of 3
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    Catch Can Install??
    Install a catch can install out of the blue today. I did the breather filter method, but should i go with the recirculating verson? Is there pros or cons to each. What do you guys think??
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Catch Can Install??
    No matter how good the can is you will never trap all of the oil vapor. If you do recirc just make sure you use the pancake valve other wise you will be sucking too much pressure out of the crank case which is worse then having too much pressure since it can cause more blow by.
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    ^^thanks for the info mike regarding the pancake valve yesterday - everything is good to go now
