Results 1 to 12 of 12
    Senior Member Two Rings bergy12's Avatar
    Mar 13 2009
    Potomac MD
    what did the dealership replace in my car?
    Ok so a couple weeks ago i got a CEL went to the dealership and was told i blew my dv. I could of guessed that would eventually happen. So i asked them to replace it with the piston style D diverter valve or (boost recirculation valve) and it was covered under warranty. They also had to replace my low pressure fuel sensors. couple days ago i was driving hard and another CEL comes take it in and leave it. I get a call the saying the diverter valve blew again. This didn't make much sense considering the D valve can hold much higher boost. but was told because of the fueling problem it blew again. So i was told i had to leave the car for the weekend. Never heard about the DV again. I was told they were replacing the low pressure fuel pump and fuel filter and were waiting on a (turbo bypass control valve). This is where i got confused to me that sounds like a diverter valve but i asked them on the when i got the first call to put in another revision D. on the invoice the only valve part number is 06F-906-283-F and has nothing about a (boost recirculation valve). Is this an older diverter valve that was just named something else or was the Revision D fine and this is a completely different part?
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Re: what did the dealership replace in my car?
    According to genuineaudiparts.com, it is listed as:
    Fuel system - Fuel induction - Turbo charger - Solenoid valve
    Solenoid valve, 2.0l 2007 - 2008
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Established Member Two Rings u_drmn's Avatar
    Jan 15 2009
    australia
    diverter valve is the same as a bypass valve just two different names
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    so dealerships cover it if your DV blows?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Mar 13 2009
    Potomac MD
    Ya they replace them under warranty but I'm just not sure it's the dv cause I've never heard of the revision "f" valve and the they call dv recirculations valves on the invoice.
    Veteran Member Three Rings Stea1th's Avatar
    Aug 25 2009
    New York
    I had my DV go a few weeks ago also, they also called it a turbo bypass control valve.
    I should check my invoice to see what they put.
    Jul 27 2007
    Orange County, NY
    How do i know when mine is out?
    I will need to re-install my stock airbox before I take it in so they dont void my warranty :P
    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    i was just in there for service for my front brakes and i think my DV has a rip in it.. finally after 50k miles chipped on the stock one.. they said they do not replace it because my car is chipped and it puts excessive wear on the part. are you chipped?
    2010 ibis white s4
    CTS Turbo intake
    Jun 23 2010
    03 1.8T Audi A4
    Mexico City/DF/Mexico
    Guys:
    Sorry If I'm confused:
    My 2.0 T had a scraping sound when I let go the accelerator, this only ocurred when the motor had load (circulating, not on neutral) noise was stronger and noticeable from outside the car when it made some effort (climb a siedwalk curb for example). The chip is stock.
    The dealer has just replaced in my car the following valves:
    06F 145 710C That is the Diverter Valve (Was replaced for the new valve 06H 145 710 D) Seen it called a N249 valve. This one has a big solenoid and is attached physically to the Turbo
    06F 906 283F That is not identified as a diverter valve but as a bypass valve. This is also identified as an N75 valve. This is a very small valve and is piped (Hoses) to the system not mounted on the turbo.
    The noise disappeared, I have checked the diverter valve and don't se any damage to the diaphgram, but it could be a small pinhole, there is no way to check the bypass valve without actuating it, haven´t done so, and I don't think I will be able to check it since one of the hose fittings (1/8" plastic) is broken.
    Oct 09 2008
    Quote Originally Posted by Fobia View Post
    Necro bump
    The warrenty is void when you chip your car.
    Quote Originally Posted by Eduardo View Post
    Guys:
    What is your question?
    The Awesome™
    Jun 23 2010
    03 1.8T Audi A4
    Quote Originally Posted by JoshDub View Post
    Necro bump
    Trying to get a clarification, the part in question is being identified in the forum as a Diverter Valve, but this part seems to be a different part (Bypass Valve).
    So as a question:
    1. Is it correct to call it DV?
    2. Can anybody tell me what is the function of this valve, (not the DV but the Bypass valve?).
    Veteran Member Three Rings CoDRoX's Avatar
    Nov 03 2009
    NoVA
    The chip is stock.
    So you're saying...
    2014 Q5 3.0T | Lava Gray Pearl/Black | Prestige | S-Line Plus | Adaptive Damping Suspension | Driver Assist | Sport Interior Package | EPL Stg I |
    Sold, but not forgotten:
    2013 allroad | Glacier White Metallic/Chestnut Brown | Prestige | Sports Package | 19" Wheels | Audi Drive Select | Adaptive Cruise Control |
    2006 A4 2.0T quattro | Black/Black | S-Line | 6MT | Bi-Xenon AFS | Navigation | Bose | BlueTooth | Tint | APR Stg I |
