Results 1 to 16 of 16
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    Bilstein PSS9 front noise follow up
    So the noise came back today on the front end of my A4 in the area of the coil overs. Kind of a clunking / groaning / bad bushing sounding noise.
    I called Bilstein, and talked to a few folks down there, and finally ended up talking to a head tech person named Steve. What's neat is he is the guy who actually developed the kit for our a4's and did all the testing on it.
    He told me right off the bat, its almost certainly the top shock mount that has failed. You shouldn't try to reuse that part on mid miles car when going to a heavy duty coil over set up. mine started to make noise when I adjusted the shock from 9 to 4 in the front, and he said thats typical and usually what happened is the extra stress load blew out the semi worn mount.
    I am going to have the fronts pulled tomorrow to confirm its the bushing, and have two new ones ready to go.
    morrow of the story, spend the $25 and replace the top mounts when doing coil overs.
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Re: Bilstein PSS9 front noise follow up
    Yup, Darren at Streetwerke who did my install mentioned that to me when they took my fronts off and noticed that they were almost shot.
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    i got a clunk in the front too, when i go over bumps in the road... probably need to replace mine! Glad you got it figured out
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Apr 05 2009
    SF BayArea
    Steve said the design of our front end makes it unusual for the springs themselves to be causing the noise. If anyone wants to install thrust bearing washers or some sort of upgraded slip washers, the size we need is 70mm ID. That makes adjustment a bit easier, and would remove any noise from the springs if it were an issue
    Thomas Sport Tuning said the Audi ones haven't been a problem very often, so they inspect and reuse them unless the customer requests new ones. (unlike VW ones which are always needing to be replaced) Seems like I am always a few weeks behind on the learning curve on my a4!
    Aug 20 2007
    97 Jeep Wrangler
    what are the washers for exactly?
    Apr 05 2009
    SF BayArea
    so the springs can turn freely without any binding. Sometimes under pressure, the front coil over designs with two springs (like the PSS9) can generate some noise from the springs rubbing under load. Also makes height adjustment a bit easier to do
    http://www.summitracing.com/parts/HA...t=HAL-7888-109
    I wish i had this second kit installed with my rear springs, which are a pain to adjust unless you lower the sub frame.
    http://www.summitracing.com/parts/AFC-20144/
    Its basically a trick upgrade over the nylon isolator the CO come with, and would replace it.
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    wonder if that's happening to mine despite it's shock/spring setup instead of coilovers. annoying noise.
    Apr 05 2009
    SF BayArea
    So got the new shock tower bushing installed on Friday, and all the groaning/creaking noises went away. But still had a clunk though in the front right wheel from time to time, and I was pissed! Turned out that one of the sway bar link bolts wasn't fully tightened,(I was able to get more than a full turn on the wrench) and that was enough to make an annoying clunk every time the sway bar went on and off load. So two different problems were the culprit, neither had anything to do directly with the PSS9 coil over units.
    Jun 22 2009
    Dundalk, MD
    Are you talking about the ring where the top of the spring meets te shock tower? When I got mine they came with new machined pieces there
    Apr 05 2009
    SF BayArea
    Quote Originally Posted by [email protected]. View Post
    No , these are the factory upper mounts that bolt the front coil over assembly to the body
    Andy
    Jun 22 2009
    CA
    Does anyone know the part number or a link for the upper mounts?
    Veteran Member Two Rings intoblue's Avatar
    Feb 15 2004
    07 S4 DTM 6SPD
    florida
    This is good news. Will try this method out. Don't know why Bilstein could not have conveyed this information to me after 5 phone calls??
    Fly's LED V4 mods, RS4 Black out grille, Full Labree exhaust with straight pipes, JHM L/W crank pulley, JHM intake spacers, K&N filter, JHM knurled shift knob, JHM L/W Frt rotors, Hawk carbon brake pads, Strat short shift kit, JHM tuned, Bilstein PSS9, 034Motorsport adjustable control arms, VMR Blk Onyx V708's
    Established Member Two Rings DANO6733's Avatar
    Nov 24 2009
    warren
    i have bilsteins and tien springs and have that popping noise too, when hitting bumps and or turning too tight.... can anyone confirm that this is my problem also?? i kind thought it was lower control arms...
    Jun 08 2009
    2013 Dodge Journey R/T
    Wetcoast of Canada
    Would this be similar in the rear.
    I have a funny noise from the rear drivers side.....
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Are you talking about the black rubber mount that 034 just released in a stiffer rubber??
    BetaAlphaTau member #19
    May 13 2008
    NoCal - EBay
    Upper shock mount is correct.
    034 just released these.
    I could use some for the rear spring mounts too. Those seem to have a wire coil on the inside I see on one of my failed ones.
    'SOFTWALKER MODS
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
