    Registered Member Two Rings
    Aug 13 2007
    Audi A4 99 Quattro
    Alternator removal.. Help please
    Ok so I was in the process of removing my alternator..
    Top bolt of thet bracket i was using an allen wrench 6 mm. For some reason the bottom is slightly bigger and sizes 7 or 8 mm wouldnt fit.
    Has this happen to anyone or is this normal?
    You think it might be an english bolt? I dont feel like removing my front end to see it..
    Senior Member Three Rings BenjaminR's Avatar
    Apr 07 2009
    Allroad, CJ5, Camaro, & lots of bicycles
    Re: Alternator removal.. Help please
    It, very well may be a 6.5mm
    Metric allens use half sizes.
    I drink a lot of beer
    Aug 13 2007
    Audi A4 99 Quattro
    Actually i kind of wrote this wrong.. 7 was a little smaller.. Do they have 7.5 mm? I've gone to shucks, autozone, and sears none have 7.5
    Apr 07 2009
    Yup I have a 7.5, I got it from a craftsman kit I bought, the ones with 900pc so idk what to tell ya, try standards sometimes they get close. Its just depends on feel, only you can tell.
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    if that alt may have been removed before and the bolt replace - since when i took off my alt the bolt was blocked by the fan - and the only way to take it out was to cut the bolt
