Results 1 to 7 of 7
    Feb 02 2013
    nottingham
    2.0t fsi multitronic rolling road problem
    G'day
    I had my car put on a rolling road at Noble Motorsport just to find out exactly what power it was producing (200bhp standard)
    The guy asked me the best way to hold it in one gear without it kicking down or changing up. As far as Im aware the only way to do this is to put in manual and not go past the kickdown point on the accelerator and he went ahead with the test.
    The results came back at 152 bhp @5500rpm (120mph) and 177lbft @3600rpm and came to the conclusion there must be something not quite right with the car.
    My question is - do you need to push the accelerator in to the kickdown position to get full power?
    In my opinion the car drives fine compared to other cars ive driven with similar power.
    Any help is much appreciated!
    Tanks
    Mar 24 2013
    Oakdale, CT
    If your car is completely stock, I don't think those numbers are outside the realm of possibility. You have a Tip (or god forbid, a CVT), so you lose more through the drivetrain than the manual guys. Even more so if you're quattro. Given the fact that the factory rating is 200 crank hp, 152 whp is about a 25% drivetrain loss. That sounds realistic to me.
    -Adam
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    X2. stock numbers are pretty sad when viewed at the wheels.
    2021 Audi S4, P34 Intake
    Feb 02 2013
    nottingham
    I think you may have a point. Ive just been out and done some 0-60 times and the times are pretty much as they should be, so those figures must have been from the wheels rather than the flywheel
    I'll have to contact the garage to clear this up. Thanks guys
    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    You need to disable traction control by pulling a fuse out.. Than it should run normal.
    Vorsprung durch Technik
    Jan 14 2013
    Mi4cxl
    london/UK
    Ps. 152 is too low should expect around 180-190
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    If that's actually BHP, something is wrong (either with your car or the dyno). You shouldn't need to push to the kickdown, since that keeps it around 5100 RPM. If I remember correctly, Audi's figures show the Multitronic beating the Tiptronic 0-60, I guess due to less drivetrain losses since no quattro, but slightly slower than the manual.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
