Page 4 of 4 FirstFirst ... 234
Results 121 to 146 of 146
  1. #121
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    Quote Originally Posted by baldy View Post
    Wasn't going to put it into the old pump. Already have a new one from Audi.
    Is there still no place to buy a new pump for less than ~$1k after all these years?
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
  2. #122
    Jun 17 2013
    jersey city nj
    Sum APR dealers will sell for $800.00 new . No Xchange
  3. #123
    Sep 10 2014
    Detroit
    Quote Originally Posted by ataylor View Post
    New OEM pump:
    http://jhmotorsports.com/shop/catalo...h=21_62_65_255
  4. #124
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Quote Originally Posted by Endmass View Post
    Pretty sure he meant upgraded pump. Either way, that's a great price from JHM.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
  5. #125
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Pretty sure john@ HPFP sells pumps for $750. Brand new, upgraded. Fancy shenanigans and all.
  6. #126
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    I've been running Johns stgII pump now for roughly 25,000+ miles with no issues so far if that helps?
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
  7. #127
    Mar 24 2013
    Oakdale, CT
    I've run a stage 1 HPFPupgrade pump for over 30k miles with no issues.
    Edit: Vizi I don't think you can claim longest running build with no issues anymore. I'm roughly 31k miles post build and my biggest issue is burning a little oil due to the larger piston-to-wall clearances required by my JE pistons.
    -Adam
  8. #128
    Jan 27 2007
    NC
    True that. Good to see another person is running with virtually no issues......
    vizi
  9. #129
    Jun 17 2013
    jersey city nj
    I ran my APR pump for 40k with no problems until the follower failed
  10. #130
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    I've got you all beat! 44k on my stage 1 hpfp upgrade pump, never skipped a beat
  11. #131
    Jan 27 2007
    NC
    And the funny thing is most don't trust his workmanship for some reason. But the ones with the most to lose use his pumps!
    vizi
  12. #132
    Jan 27 2007
    NC
    Quote Originally Posted by vce1232000 View Post
    Yeah, CF's just suck! That's why I change mine every 10k regardless but unfortunately I know it can break 100 miles into its use.
    vizi
  13. #133
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Black Friday deals coming up...... If you can wait that long.....
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  14. #134
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    My stage 2 HPFP has lasted two Audi's and over 50k miles.... So got all of you beat ha ha ga
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  15. #135
    May 11 2010
    BC
    Ok, to be fair, my Autotech lasted over 65,000 miles. So maybe I have you all beat, but just can't help to wonder if there is a better option I guess. The main design feature of the HPFP Upgrade, Corksport, LOBA, APR (CP-E) which I think would help with longevity of the cam followers is the button retainer. I never had any fuel leaking through the seal, etc. So on that note, it has been reliable and I'm not complaining. It's just if there is a better option, now would be the time to upgrade.
    I guess I'll see what Black Friday brings.
  16. #136
    May 20 2010
    So...reviving this thread for a question:
    My hpfp has a crack across the connector, and I was looking up the part number via ECS. IIRC, my car originally came with Rev K, but I noticed the latest OEM rev is M (06F127025M vs 06F127025K). Does anyone know what the difference is?
    GAP tells me this same hpfp is used up to the 2015 TTS (265 hp, 258 lb-ft -- essentially B7 2.0T Stage 1). APR Stage 1 for that car says it requires no hardware, and it's somewhere in the ballpark of >350 hp and 350 lb-ft. Stage 2 also doesn't have any additional hpfp updates. Could the update been to stronger internals?
  17. #137
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Will a upgraded HPFP do any good on a K03 with a turbo-back exhuast?
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  18. #138
    Senior Member Three Rings BeeSevenKyle's Avatar
    Feb 24 2019
    2011 Dodge Journey R/T AWD
    Ontario
    Quote Originally Posted by Flygman View Post
    Unless your car is tuned, I don't think so. Someone may correct me but I think stock fueling vs upgraded won't make a difference in a stock car.
    Sent from my VOG-L04 using Tapatalk
  19. #139
    Jan 27 2018
    Gothenburg
    Quote Originally Posted by BeeSevenKyle View Post
    Yeah that makes sense, but can more power be gained from tuning a K03 with an upgraded HPFP?
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  20. #140
    Feb 24 2019
    Ontario
    Yes, a stage 2+ tune will require a test pipe or HFC, intake, and a fuel pump upgrade
  21. #141
    Senior Member Two Rings arankaspar1's Avatar
    Feb 20 2018
    Oakland CA
    Would an RS4 HPFP be equivalent or better than these upgrades?
    I have a K04, S3 injectors, cat-back exhaust, stock HPFP/Cat.
    I need a new tune.
  22. #142
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by arankaspar1 View Post
    I need a new tune.
    https://www.audizine.com/forum/showt...light=jhm+tune
  23. #143
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I need a new tune.
    Stock hpfp with a k04?? That can't be good, lol.
    Sent from my LM-G710VM using Audizine Forum mobile app
  24. #144
    Dec 25 2017
    Sweden
    I need a new tune.
    AFAIK the RS4 has a roller follower. My roller follower is certainty off of an RS4 B7. So I would “guess” the HPFP is incompatible without a bunch of modification.
  25. #145
    Feb 20 2018
    Oakland CA
    Quote Originally Posted by Jayz691 View Post
    Yeah current bs tune is pulling 20-30 degrees total timing at 45% load. Timing decreases when load goes up. Its requesting only 1600mbar at it's peak. I think I'm going GIAC because it's 91 and easiest of all for smog.
  26. #146
    Feb 20 2018
    Oakland CA
    As low as 250mbar requested boost when actual is 1170 and the waste gate isn't opening.
