Results 1 to 9 of 9
Hybrid View
    Veteran Member Three Rings americanthunder's Avatar
    Feb 18 2009
    New Hampshire
    Stage 2+ spark plug question.
    Heres my mods Apr v5 93 file, test pipes, darintake mod, awe twin1 catback, ebay fmic, bailey dv's. I've searched this question and haven't really found a positive answer. Im due for new spark plugs and Im not sure if I should go with the NGK BKR6E or the NGK BKR7E 's. I've found split results, some say stock some say go with the colder plug. Can anyone tell me whats the better plug to run on a stage 2+ ? TIA
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Stage 2+ spark plug question.
    Stock plugs are fine. You only need colder plugs once you go stage 3
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I personally run the 7E's... but it's true, its not really needed.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    i run the 7es's in my drag car, so i bought extra and am going to run in my s4 stage 0... if i have issues i'll go with the stock heat range.
    Jan 29 2009
    Quote Originally Posted by fshowcars View Post
    There's no reason to have issues with NGK 7's (unless you have other problems with your ign system)... as they don't foul in our motors... which is the whole thing about going too cold... If you go 9's I could see an issue maybe
    So yes, you can run a 7 in a stock 2.7t all day long and never have an issue.
    Feb 18 2009
    New Hampshire
    thanks for all the responses, just an update I went with the 6's and It runs mint
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    I'm running the 7s-one heat range colder. No problems...I like them...Stg 2+
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Established Member Two Rings nuklearmaniac86's Avatar
    Feb 06 2009
    Virginia
    I just got these BKR7Es and am stage 2+ also. Should I stay with the stock .28" gap? or go with a different gap with these plugs?
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    Quote Originally Posted by nuklearmaniac86 View Post
    .028 gap
