Page 3 of 3 FirstFirst 123
Results 81 to 83 of 83
  1. #81
    Veteran Member Three Rings Rirruto's Avatar
    Dec 09 2009
    Ocala
    I was looking at this same sub. Did you run it off the stock amp? If so, how does it sound?
  2. #82
    Jan 28 2018
    Audi B7 A4 Sline
    Columbia, SC
    Quote Originally Posted by b spot View Post
    Update:
    I spent about 15 minutes shoving rags under the rear deck and have the rattles 90% eliminated. A lot were from the wires leading up to the brake light and trunk light assemblies. I'm actually pretty happy with it now, you can have the bass up pretty loud and it still sounds pretty good, even though normally I don't like to have the sub super loud.
    Reviving this thread. I thought my subwoofer was blown, but I don't think it is after reading this thread about 3 times. I tried the rags under the rear deck. I think there is an improvement. I will continue to monitor it and see. May have to look at a subwoofer upgrade. I hear more base out of my front door speakers than the subwoofer. It is weak for sure except when it is rattling...haha!!! Thanks.
  3. #83
    Dec 28 2008
    Bringing this back. For those that had done this, is there room to just make a template out of MDF and use that for the sub mounting? I saw a similar build out with a Elemental Designs sub but wasn't sure if it would be possible to use MDF and still get it under the deck with removing all the trim.
