Results 1 to 6 of 6
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    Dipped headlight warning store code?
    I'm just wondering if a dipped headlight warning stores a code in the ecu? It happened too me, then the headlight turned off then back on. I can't find the code in vag-com so i'm afraid the dealer wont fix it.
    2013 S7 Phantom Black on Black diamond - loaded
    2009 Audi R8, Black on Black w/ Blown V8 and black ADV.1 7.1's. (Carbon, Alcantara, Etc.) - Sold
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential - Traded.
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
    Registered User Three Rings 05.5SilverS4's Avatar
    Jun 14 2009
    2005.5 S4 , 2000 Yamaha R6
    Fishers, IN
    Re: Dipped headlight warning store code?
    Quote Originally Posted by TurbousMaximus View Post
    Sadly mine didnt show in VAG either. Best bet is to take it to them when it dips and have a mechanic note it for when you take it in to them. Also, if its dipping its probably the headlight going out which my dealer wouldnt cover. So i did it myself for about $80 for two new bulbs and some manual labor out in my garage.
    Aug 25 2004
    Whitehall, PA
    doesn't the bumper need to come off to change the bulbs?
    Established Member Two Rings jiffy946's Avatar
    Jan 01 2009
    2002 A4, 2006 TouaregV8, 2005 S4 Avant
    Arvada
    If you turn the vehicle off, it will NOT store any faults. To ensure that the dealer can accurately diagnose the problem, you need to take it to them with the dipped headlamp warning illuminated. Do not turn off the vehicle until they have pulled faults. Typically the only way warranty will cover a xenon bulb is if a module has failed, causing a bulb to fail as well. I do not believe the bumper needs to be removed for xenon bulbs, but I do know that it does need to be pulled for the modules(on the bottom of the headlamp housings).
    Jun 14 2009
    Fishers, IN
    Yes but the DIY makes it relatively easy. I had never touched a bumper before i did mine and i can say it was pretty painless if you have the time and patience. Its $80 vs $400+
    Senior Member Three Rings ked's Avatar
    Feb 19 2009
    C7 A6 3.0T Prestige
    SouthSIDE Chicago
    No codes. Dealer replaced my bulb, problem was still there. Dealer replaced wires, problem still there. Dealer replaced my ballast... Ahh ...problem solved. :)
    2012 A6 3.0T Prestige
    2006 A4 3.2 SLINE Tip (August 2006-August 2011)
    2008 A4 2.0T SLINE Tip (Gone; TERRIBLE)
