Page 6 of 6 FirstFirst ... 456
Results 201 to 221 of 221
  1. #201
    Veteran Member Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    *Update- 6 years later- May 17th 2015.
    The clutch finally started to slip (likely caused by me not fixing a rear coolant flange leak) and the slave cylinder went as well (I shouldve use a new one at the time).
    Pulled the transmission to replace it again with another FX400 and everything seemed to be just intact the way I left it. The pilot bearing was in the exact same spot and seemed like it was stuck in the flywheel pretty good after all the time of debris/random shit getting inbetween the 2 surfaces. Replaced the pilot bearing without another one from Zorkos although the original one seemed to be just perfect still.
    summary- replaced clutch after 6 years, pilot bearing method seemed to have no problem.
    Is this plate worn all the way?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
  2. #202
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Nice update!
    Sent from my SCH-I605 using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
  3. #203
    Dec 26 2014
    woodbury ct
    Chris, that friction plate/ clutch disc is definitely not worn 100% yet.
    Usually they start to really slip, you pull it apart, and you are rubbing on the rivets...
    Glad you got 6 yrs out of it!!!
    Good clutch, flywheel will need a nice scuff since its glazed
    You ever have a problem with the plastic bleeder screw on the slave cylinder?
    sent from my galaxy sIII using tapatalk
  4. #204
    Jun 04 2007
    Austin/DFW, TX
    Sounds like my failing slave cylinder + coolant leaking on my transmission probably caused this to happen. 6 Years and 40k miles.
    I got my flywheel resurfaced and a new clutch altogether. I have not had problems with the bleeder screw.
    Quote Originally Posted by wolfman114 View Post
    My 5-Speed Swap DIY
    - B6 USP
  5. #205
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    Not sure if this was in the diy or not. But am wondering can I cut the old auto trans wires and tcm harness and heat shrink the wires and get rid of excess wire and the tcm box and not have any issues?
  6. #206
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    Quote Originally Posted by crazexr7 View Post
    I just cut mine off, and removed the TCU. I didn't remove all the wires.
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
  7. #207
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    Quote Originally Posted by biketsai View Post
    Day 2/3
    Afterwards take off the clips that hold the rod for the brake pedal, insert the new rod and put the assembly in without the clutch pedal in. This section will all make a lot more sense once you get in there. I bolted the clutch master cylinder first to the bracket. Remember that you must use the new longer push rod for the pedal and clutch pedal. Once you have the assembly in the car, you can then clip the hardline to the clutch master cylinder (there is a grommet you must remove for that spot). Then get your vac hose for the clutch master cylinder to the brake reservoir and connect it all (on the reservoir just cut off the closed end). Afterwards just install everything back.
    Pedals in:
    Sorry to bump your thread but reading through this before manual swapping :) Been a really useful thread thank you!
    Just wondering what you mean by longer push rod?
    Cheers!
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
  8. #208
    Nov 06 2015
    Frankfort Il 60423
    The longer rod he is talking about is the one that holds the brake & clutch pedal in. When you remove the brake pedal there is a rod that has clips on each in, ( it is the rod that the pedal pivots on) remove one clip from the rod and push it out. Your new rod will be much longer because it holds both pedals in. A little tip to remove the brake push rod from the booster. Remove bolts and lines etc. from brake booster, pull it back a little bit, then go back under and see the rod, Take a 3/4 wrench and 17 mm one. back off the large nut a little, its a lock nut for the ball rod that goes into pedal. Un thread the ball rod and the pedal will come out or fall off. When its out, lay pedal rod face up and use 2 small blade screw drivers and press in the plastic clips on the side of the ball rod, out she comes. Hope this is just as clear as mud.
  9. #209
    Feb 09 2007
    00 S4
    MA
    Bumping an oldie but goody. I followed this procedure when I swapped my 1.8TQ auto to an O1E 6-speed. Used the same alternator bearing in a AASCO LWFW with a southbend stg 5 clutch and have put about 40K over the past two years on it. NO PROBLEMS! Not a single problem related to the driveline. Plenty of problems with the rest of the car tho lol.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
  10. #210
    Junior Member Two Rings
    Feb 05 2016
    Barry/IL/USA
    I looked up on ebay some of the parts like the rear driveshaft and the cheapest one was $300...the transmission was $200...what the heck? I was unable to find a 3.89 ratio rearend though...looks like im sticking with the TIP for now :(
  11. #211
    Sep 13 2012
    Adelaide, AU
    Quote Originally Posted by bruejones View Post
    There's your problem. eBay is not the chepsest for second hand, bikestai sourced his parts from wreckers like most do and found good deals
    Sent from my Nexus 5X using Tapatalk
  12. #212
    Feb 05 2016
    Barry/IL/USA
    I just saw this car that was swapped on Facebook for sale...its in Iowa
  13. #213
    Active Member One Ring kristian1909's Avatar
    Dec 22 2013
    My wrecked a4 b5 1.8tq:(
    Moss Norway
    This tread helped alot when I swaped my tip to a 6speed 01e. I think the 6speed was esier because you don't have to swap the rear diff and subframe/custom gearbox mount?
    Great tread though! :D
  14. #214
    Feb 05 2016
    Barry/IL/USA
    I know this is an old thread But did he change the rear end
  15. #215
    Jun 30 2008
    Erie, Pennsylvania
    According to this For Sale thread on VWVortex, yes, he did swap the rear differential to the correct 3.889:1 ratio to match his 5MT 01A transmission. From memory of a conversation with him *way back*, I think he only ran the incorrect auto rear diff for a very short time before completing the swap. Nothing exploded, and the car drove ok, but it will wear the center torsen differential long term unless you correctly match the rear end.
    https://forums.vwvortex.com/showthre...-Rear-Diff-DAK
  16. #216
    Aug 17 2017
    Two 99 A4 1.8t manual conversion in progress
    Dayton NV
    Do this soon
    I'll be doing this conversion soon to my 99 1.8t so will probably have questions. I have a 99 1.8t parts car for manual parts, but will I need a drivers side mount from a 2.8 to apply to the automatic car to make the manual trans fit?
  17. #217
    Feb 23 2013
    B5/S4,MkI Scirocco, Rabbit Truck, allroad, mkV Jetta, T1 Touareg V8
    KC, MO
    Quote Originally Posted by DaytonCarCare View Post
    Yes, that is the simplest way for most so that you can keep the same subframe. The other solution is swaping the subframe from a manual 1.8T which you seem to have.
    The only other part to make the swap a "bolt-in" is using the adapter to convert the tip crank to accept the pilot bearing that I manufacture:
    1.8T-Tiptronic-to-Manual-Pilot-Bearing-Adapter
    If you need the 2.8 LH bracket and/or adapter, I can provide both.
  18. #218
    Aug 17 2017
    Dayton NV
    Still a work in progress
    Quote Originally Posted by Gearbox View Post
    Wow can't believe it's been 6 months already and still haven't gotten this done. Debating whether or not to swap the sub frame. So far just took out the drive line components for the swap and also the pedals, slave cylinder and line from the manual parts car. Have the same removed from auto car but still on jack stands ready to drop the auto trans. I'm reluctant because it's colder outside and the trans is super heavy but eventually will get to it. I did find someone that sell an aluminum adapter to fit into the auto trans crank for the pilot bearing so manual trans fits correctly and he has the driver side V6 bracket I need so with probably order as a package.
  19. #219
    Aug 17 2017
    Dayton NV
    Last 2 days
    Torque specs for the next steps (they may differ depending on your setup)
    -FW-60ft lbs (non stretch bolts)
    -Pressure plate- 14ft lbs
    I was reading in my repair manual that the specs for the FW is 44 Ft lbs and PP is 18 Ft lbs just FYI for future reference. I'm about halfway done. Dropped the trans, mounted the pedals, lines, cylinders, FW and clutch, and shift linkage, so getting there
  20. #220
    Aug 17 2017
    Dayton NV
    ReCoding
    Recently finished mine. I know about recoding the ECU from auto to manual with software to get rid of CEL for missing TCU, but is there another way? Possibly run a jumper from ground to a pin or wire on the TCU harness. I don't have the software easily available is the reason I ask.
  21. #221
    Junior Member One Ring DJ GLO's Avatar
    Jan 30 2012
    Olathe, KS
    I just finished my swap too! Thanks for this amazing thread :)
    However, when I'm driving in-gear, there is a rotational rattle / scraping sound that that appears to be coming from the bell housing. I started a thread about it here if anyone is able to help:
    https://www.audizine.com/forum/showt...er-manual-swap
    DJ GLO - http://www.djglo.net - 5-speed manual swapped 2004 VW Passat 1.8T AWM FWD
    GIAC Stage 1 ECU/Touareg 17Z BBK/Aluminum uprights/Jetex Exhaust/Techtonics DP/034Motorspot HFC/Eibach Pro Kit Springs/Bilstein B8 Sport Shocks
