Results 1 to 36 of 36
    Jul 18 2009
    Audi rs4, BMW m5, transporter t4, vw Lupo, Audi a2,
    Denmark
    Fault code: 18084 EPC
    Hi,
    First of all, sorry for my bad English...
    I have a problem whit my S4 2000.
    my EPC lamp is on and there is in the engine management a fault code there says:
    18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
    P1676 - 35-00 - -
    I have brand new Instrument cluster and Engine management.
    I have also borrowed a throttle body and a speeder pedal but that’s the same.
    When I erase the code i can drive the car for 1 maybe 2 days and then the lamp/fault code is back.
    any ideas?
    Jul 18 2009
    Denmark
    Re: Fault code: 18084 EPC
    now i have cheked the wiring harnes near the ECU and it looks perfect.
    is there no one whit an idea?
    Jul 18 2009
    Denmark
    i cant figure out what could be the problem.
    but i found a new thing i cant understand....
    my 2 x ETG´s show 945 degrees whit engine running and 1035 degrees whit engine off. is that normal?
    got damn, I love this Audi...
    Veteran Member Four Rings mholme's Avatar
    Jan 29 2007
    08 S4 00 S4
    MD
    Those are normal EGT readings. Why did you replace the cluster and the ECU?
    08 S4- Stock SOLD
    00 S4-APR 93 Piggies Custom True Dual exhaust AWE DTS ECS/Bilstein Coilovers 710N's Samco TBB Omori 52mm boost gauge SOLD
    Jul 18 2009
    Denmark
    actually it happend the day before i bought it. it was stolen and the things where missing when they found it. i bought it from the insurance company.
    the things was installed by Audi (In Denmark that is not necessarily a good thing)
    Today there has not been any trouble, and i have started it for about 50 times now.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    Now it´s back...
    i have to delete error codes 5-10 times before it´s gone again.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I feel your pain.
    I was having codes of intermitant throttle body codes, finally replaced the wiring harness and now those codes are gone,
    but have this same code that you have now.
    I'm thinking it may be something with the wiring harness how it hooks to ecu.
    I'm going to make sure the connections are all plugged in tight again.
    But if anyone has answer to these codes, that would be great.
    The ross Tech site says this about these codes:
    Possible Causes
    EPC Warning Lamp (K132) faulty
    Wiring/Connectors from/to EPC Warning Lamp (K132) faulty
    Engine Control Module faulty
    Possible Solutions
    Check EPC Warning Lamp (K132)
    Check Wiring/Connectors from/to EPC Warning Lamp (K132)
    Check Engine Control Module
    Retrieved from "http://wiki.ross-tech.com/index.php/18084/P1676/005750"
    I have two ecu's to test with. so I really dont think this is the cause. i think the wiring connection to or from epc warning lamp is the problem. At least in my case.
    For you i think it has something to do with replacing cluster
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jul 18 2009
    Denmark
    I will take my cluster out today and check the wirring in that end.
    i noticed that i only have 2 x o2 sensors, is that correct? a guy told me i should have 4 of them on a 2000 (2001 model).
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    all models should have 4.
    2 pre cats and 2 cats
    GIAC-X, STASIS TS,VAST,034 MS
    Jul 18 2009
    Denmark
    Ok....
    where do i find the connectors? i cant find any loose one´s....
    and another thing... why do i not get any error codes?
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Nov 14 2006
    Land of the Eagles
    2 od them are black colored connectors ther other two are brown and green.
    Jul 18 2009
    Denmark
    i dont have 4 on my car. on some European model there is only 2 of them.
    i have today measured the signals between Throttle and ECU and between ECU and the cluster, and everything is all right.
    Now I am lost.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Nov 14 2006
    Land of the Eagles
    ohh i forgot ur in denmark
    but anyway, those should not give a code for EPC
    Jul 18 2009
    Denmark
    I agree in that.
    i have made a new wire between ECU and cluster. Ecu/48 to Cluster T32a/13.
    no problems so far...
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Still no problems? Keep us up to date on if this fixed your problem or not.
    Jul 18 2009
    Denmark
    still no problems... i have started about 50 times now...
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    and then its back.....
    I can only think cluster or ECU now.
    any ideas?
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Dec 14 2008
    Finland
    I´ve had same problem/code for years, didn´t find what caused the 18084 code so I gave up ;( I did try another ECU but it didn´t help so don´t think that will help you either.
    There is a small possibility you have wrong instrument cluster.. I´ve been told theres some differents between the clusters (Depending on year model or something..) even they look the same. Don´t know if thats true but you could check it out.
    Did you have this problem with the old cluster instrument before you car was stolen?
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Yes these codes are frustrating.
    I did find this post:
    http://www.audizine.com/forum/showth...43#post3986443
    On that post a person who had both these codes together said he fixed it by replacing the throttle body.
    That may sound strange, but to me it doesnt because of the problems I've had since June. Its in this post here:
    http://www.audizine.com/forum/showthread.php?t=289710
    Read the entire thread ^^^ and you will see how this stupid 18084 epc light could be related to the throttle body.
    I'm thinking I still mayhave a faulty throttle body even though I've tried 3 used ones, but I dont know for sure.
    The other thing is I know my negative post on my battery looks like it might not have a good connection, so I want to clean that up and make sure its got a good connection, I'm hoping that may help it too, but I doubt it.
    I will say this about this error code. If I start the car when its cold and drive it for any distance (could be 2 miles or could be 200 miles) the light will not come on. But if I shut it off and then go to start it again with the engine still warm, the epc light will immediately come on and stayon. It doesnt affect boost but has the code listed in this post. So it seems to be affected by heat.
    Anyway if anyone else was able to fix this code. please chime in.
    Jul 18 2009
    Denmark
    im 99,9% sure mine is gone now, i have not seen it since friday and it would normal have been back.
    i hope!
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    and then it´s back!... CRAP...
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    EDIT:
    Now I am (almost) 100% sure, it was my 4month old cluster there was the problem, I borrowed an old cluster and I have not seen the problem since, tomorrow I’m going to order a new one.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    May 01 2005
    Powell, Ohio
    check to make sure your TB connector has good connection then adapt it aswell
    04 evo 8 rs 2.3l stroker | 02 gti 1.8t | VW Tech
    grave yard
    Lexus Tech | 99 a4 | 91 talon tsi | 96 jetta | 87 TII rx7 | 88 10th ann. rx7 | 89 turbo supra
    Jul 18 2009
    Denmark
    Quote Originally Posted by skold View Post
    Done that twice, also tried another TB. I’m sure it’s the cluster.
    but thanks anyway!
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    This problem is still not solved.
    i have now changed:
    gas pedal.
    thottle body.
    battery.
    instrument cluster.
    map sensor.
    maf sensor.
    ign contact.
    all new OE parts.
    Any ideas?
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Nov 14 2006
    Land of the Eagles
    damnn this sux.. this is why am scared of S4's..
    maybe a relay?....wiring harness? ECu?
    Jul 18 2009
    Denmark
    Today i order ALL relay.
    I maybe get a ECU today also.
    i have a complete harnes maybe i should try that today.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Jul 18 2009
    Denmark
    A guy in here told me to recode my cluster (it was 00164 now it´s 00064 and the problem is gone....;o)
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Oct 30 2007
    Lynchburg, VA
    Just recently replaced my cluster from an A4 and I am having EPC light also. How did you recode your cluster?
    Jul 18 2009
    Denmark
    You have to do it Whit VAG-COM/VCDS.
    Mine is perfect now, it´s very nice...
    now it´s time for coilovers, brakes and wheels. I need a good advise about the brakes... whats the best to buy?
    today i have RS4 B5 but i want some 6/8pot, but whats the best?
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Senior Member Three Rings EtanClan's Avatar
    Jul 24 2007
    '02 Silver S4 6spd
    Lincolnshire, IL (Chicago)
    Quote Originally Posted by Jesper S4 View Post
    So following this.. http://wiki.ross-tech.com/index.php/...Cluster#Coding
    ...you changed it to German and it's worked?? Did your ECU come from an S4 in Germany?
    '02 Audi S4 -- Stage II: silver on black, 6spd
    Jul 18 2009
    Denmark
    my S4 is from italy and i live in denmark and the ECU is bought in denmark when the original got stolen.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Dec 14 2008
    Finland
    I was on a right track...after all
    I am very glad that you got the problem solved
    I would also like to know how did you recode the cluster, step by step.
    edit: slow brain but got it :)
    Jul 24 2007
    '02 Silver S4 6spd
    Ah gotcha..I've got the same problem...I'll have to recheck my instrument cluster coding.
    Jul 18 2009
    Denmark
    I almost forgot:
    THANKS to ALL for the help whit my problem.
    Jesper Pedersen.
    Audi Rs4 2001.
    Wagner DP's.
    DIY Exhaust.
    Bilstein Pss9.
    Nov 14 2006
    Land of the Eagles
    No prob. buddy glad it got fixed
