Results 1 to 16 of 16
    Established Member Two Rings Pestilaence's Avatar
    Nov 21 2008
    2004 Audi A4, 2003 Yamaha R6
    Bloomington, IN
    Sound coming in and out? Bad amp?
    Hey guys, I have a question concerning my B6 A4. I figured I could ask it in here since it has to do with my stereo and or the amp. I have the stock Bose system and it's a 2004, if it matters. I've noticed for a couple weeks now that the sound from my stereo seems to come and go... it doesn't really shut off, the sound just gets really quiet, and then goes back to the normal volume a couple seconds later. Then, it does it again shortly after. The best thing that I could think of is that there is a connection loose, or that the amp is going bad.
    Has anyone had this happen to them, or could you guys tell me what you think might be wrong? Thanks in advance!
    Senior Member Two Rings Kevin7's Avatar
    Feb 05 2009
    F80 M3, E60 M5
    Irvine, CA
    Re: Sound coming in and out? Bad amp?
    Happens to me too on occasion; figured it was the DICE unit but maybe not since you mention it on a stock system!
    Nov 21 2008
    Bloomington, IN
    Yeah I have the Bose symphony stock unit. My best guess is it's the amp, but I figured it shouldn't be going bad this soon.
    Established Member Two Rings whodatt's Avatar
    Oct 30 2007
    02 Audi A4
    Madison, WI
    I have a similar issue with my stock bose stereo. the front passenger side tweeter cuts in and out at times and/or will crackle, like it has a loose connection or something. Is there just one central amp with the stock stereo or is there an amp for each speaker?
    Sorry if I'm hijacking your thread, just sounds like a similar issue and I don't know much about the configuration of this car's stereo system.
    Nov 21 2008
    Bloomington, IN
    If your speaker is crackling, then it almost sounds like it's going bad, or is blown. An amp wouldn't cause a speaker to crackle like that...
    Mar 27 2009
    01.5 S4
    SF Bay Area
    Quote Originally Posted by Pestilaence View Post
    Sounds like a clipping amp to me, or bad voltage from the headunit to the bose amp. Definitely test the amp and/or headunit; you're on the right track here.
    If it were a loose or poor speaker wire connection, you'd have NO sound, not low sound.
    Nov 21 2008
    Bloomington, IN
    Yeah, I figured it wouldn't be the speakers... I'll see if I can find a way to test the amp. :/ Thanks!
    Established Member Two Rings B61.8T's Avatar
    Sep 19 2006
    Silvia, B6 !.8T
    MD
    Where is the amp located?
    2002 B6 1.8T FWD
    19" August Werks with Perellis, VOTEX Body Kit
    Future Mods: HID Bi-Xenon, BT setup.
    Interior: Gauges, Carbon Fiber, AVIC D2, 10" SUB.
    Veteran Member Three Rings misterjj2u's Avatar
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    Amp should be located in the trunk area. I have an avant so for me, it's on the rear right side of the trunk area.
    My car had the same issues, but only on hot days. Not sure why. I went to the dealer and they told me it was b/c of my aftermarket exhaust (what a bunch of crap).
    I think it has to do with the amp overheating but I have yet to figure out the solution. If I cool the cabin temp down w/ A/C and air flow, the noise fluxuations go away.
    Problem is: now my A/C goes in and out. :/
    Feb 25 2009
    New Jersey
    I am getting the same issue with the stereo and also the a/c. i checked my a/c freon and its fine. Any solution?
    Feb 25 2009
    New Jersey
    i found another thread that will help:
    http://www.audizine.com/forum/showthread.php?t=303025
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    Good find. Lame that AoA won't fix the known problem under CPO though.
    Established Member Two Rings Patate's Avatar
    Nov 07 2006
    A4 Avant 1.8TQ USP, Porsche Boster S 987
    Montreal
    Same problem for me on my 05 Avant, dealer said its nothing wrong...
    Cant listen to loud music for a long period of time, im pretty sure its the amp as well
    2005 A4 Avant USP
    __________________________________________________ _______________________________________________
    REVO / Milltek exhaust / Milltek HFC / RS4 Sway bar / RS4 Pedals / K&N / KW V2 Coilovers / BBS CK 19" Antracite
    Montreal Audi Club #13
    Active Member Two Rings jbone's Avatar
    Aug 12 2008
    North Vancouver, BC
    its the head unit i guarantee it, whenever i was driving the sound would dicipate and then come back. I changed out the head unit and poof never happened again.
    Aug 24 2008
    Parker, CO
    My car does this as well, thought it was the head-unit so replaced it. Same thing still happening.
    Established Member Two Rings UncleDave's Avatar
    Jan 21 2010
    2002 S6 Avant
    I have a 02 S6 Avant with RNS-E. Driver side door speaker cuts out completly at random. Whats wierd is if I CRANK the sound up if comes back online. I'll look into the amp area for loose connections first. I have the RS6 exhaust also, might be the culprit as well.(someone posted aftermarket exhaust causing extra heat back there affecting the amp somehow??)
    Sorry to revive an old thread, but if anybody had success fixing the speakers cutting in and out, please advise.
    Thanks
    UD
