Results 1 to 8 of 8
Hybrid View
    Active Member Two Rings burn2burn's Avatar
    Apr 15 2008
    '08 A4 2.0T 6MT SE S-Line
    sOCAL
    iPod integration problem
    I've installed the blitzsafe iPod adaptor (BlitzSafe VW/M-LINK1 V.5
    ) for my b7 2008. However when I press the cd button twice it doesn't switch to the iPod mode and the satelite as well as everything else works fine. I'm stumped. What could it be? Thanks in advance.
    Jan 18 2005
    North NJ
    Re: iPod integration problem
    Did you ground the black wire with the ring terminal at the end?
    Apr 15 2008
    sOCAL
    Thats exactly what did the trick! Thanks!
    Follow up question - is it normal to have a slight hiss with this unit? That's what I'm hearing when there is no audio being played, it's not too much notacible while playing music.
    Jan 18 2005
    North NJ
    Where did you ground it?
    Apr 15 2008
    sOCAL
    on the chasis of the radio. on the side via the larger hex fastener. i couldn't really find any other location.
    Dec 22 2008
    WA, USA
    Quote Originally Posted by burn2burn View Post
    Super off topic, but I love your avatar, love that show!
    May 18 2008
    tn
    find another ground, i had the same issue. i ran a long wire to a place under the dash where i could scrape paint and get a good ground. Cured the hiss.
