Results 1 to 6 of 6
    Established Member Two Rings dj_hp's Avatar
    Apr 30 2009
    '99.5 A4 1.8TQM | '88 BMW 325i
    Toronto, ON
    Compression Surge Sound??
    http://www.youtube.com/watch?v=CNt7aO-rSoI
    I know this is not normal. I'm wondering what this could be?
    Sorry if this has been discussed before but I just don't know what to search it under.
    Also, sorry for the bad video quality. But hopefully someone could help.
    **EDIT: The sound is coming from the intake box.
    Could this mean my DV is going? The sound I'm talking about is the surging sound after throttle release.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Re: Compression Surge Sound??
    do you have a stock DV still? its probably shot after 1xx,000 miles
    Apr 30 2009
    Toronto, ON
    Yep it's stock DV.
    Lol I only have 61,xxx miles..
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    one fast moped
    NJ/NYC
    I'd make sure your DV hoses arent kink'd. Sounds like the air cant devert...forcing it to push back over the spinning blades. Could be a bad DV as stated above as well.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Senior Member Three Rings PoormansA4's Avatar
    Mar 26 2009
    Wildomar,CA
    there was a TSB floating around before on how to check it, if i remember correctly you take it out and take a socket extension and push the piston in then put your finger on top of the vac line on top and release the extension, the piston should stay up and when you release it should shoot back down
    For sale
    wiring harness 01 1.8t
    map sensor
    stock injectors
    fuel rail
    stock FPR
    brand new front and back rotors (quattro)
    Aug 13 2008
    Indiana
    Like others said if its a surging sound its probably the DV. Though it's hard to tell w/ the video. I would check for any boost leaks as well.
    -Nic
