Results 1 to 31 of 31
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    Best Turbo Solution for Tiptronic for under $3K
    I've got a '00 1.8 Tiptronic with the ATW. And I could use some advice.
    I've seen some deal on here recently, one imparticular was a K04 kit including:
    K04, Racetec Intercooler. Software. FPR for around $2200 (I forget exactly).
    I'm wondering if there is a better option, my car is currently stock performance wise, and dont want to spend more than $3K. I'd like to get as much as possible for the tiptronic for that budget. Can someone give me any suggestions or point me in the right direction?
    Any other options than a k04 for the tip? should I try to piece everything together or go with a bundled kit?
    Hooray for boobies!
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: Best Turbo Solution for Tiptronic for under $3K
    For $3k........Stick with the K04
    You could also research this
    http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
    But after you buy everything else that is needed I I know you would be way over budget
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Dec 05 2007
    ^He really would not be that overbudget. If anything, he would be cutting it rather close (maybe $100-200 extra), assuming he already has an exhaust set up.
    GTRS Kit: $1,500
    TIP: $150
    Tune and Injectors: $1,000
    FMIC: $250 ebay kit
    MBC: $50
    FPR: ???
    Guages: ???
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    I would go with an eliminator kit if I were you or some sort of gt2871 turbo. After you sell your stock parts, you would be in the $3k range.
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Noooo, do not go with the K04 unless you want to kill your transmission quicker. The torque from the K04 is too much for the stock tranny. Id go with a GTRS, or you can buy my PES T28 kit!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 27 2006
    Fargo, ND
    Kit with REVO software $2700+TIP($300)+FMIC - So depending on FMIC and if your going to install this yourself, then you might be close.
    http://www.ecodetuning.com/shop/cart...t_detail&p=504
    Wasn't considering the Ebay FMIC as the core of choice, so $750+. And yes the GTRS will be way less torqy than the K04 so it's actually better for the trans.
    Whatever you decide - Know everything before you start buying piece by piece so you know you final cost. Maybe call 034 or ecode see what they suggest.
    2008 Honda Pilot SE
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by akielb View Post
    Im surprised that they dont include the TIP for that kit. Thats another $250
    My 5-Speed Swap DIY
    - B6 USP
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    034 gt28rs elim kit :)
    TEAM|AXION
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by speedydragon View Post
    hows that working out for ya?
    My 5-Speed Swap DIY
    - B6 USP
    Mar 26 2005
    I pulled on a lowered NA 240sx with wide wheels and huge exhaust on 2 consecutive 35mph S turns..we were both flooring it through the apexs. I heard him down shift to 2nd or 3rd and gunned it :D
    TEAM|AXION
    Jun 04 2007
    Austin/DFW, TX
    Nice, moments like that make me wish I had an avant. Im upgrading to 550s pretty soon, so hopefully I can hang haha.
    My 5-Speed Swap DIY
    - B6 USP
    Mar 26 2005
    haha yea, the guy didn't even know what happened. He looked all perplexed when he was paseed by an avant so easily :|. When are you getting that new tune?
    TEAM|AXION
    Jun 04 2007
    Austin/DFW, TX
    Ah, still waiting on it
    Ill be running 550cc injectors or 630s. I really hope it is quick after that! I should have just bought everything new from the get go.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 27 2006
    I pieced together a kit.
    Got a K04/gasket kit & Hardware
    FMIC
    5 Bar FPR
    034 DV
    Boost Guage and pod
    Next I need to order the software? Any suggestions?
    Also anything else Im missing?
    Do I need to upgrade/replace N75? If so which is best?
    Hooray for boobies!
    Jun 04 2007
    Austin/DFW, TX
    Uh, GL to your tranny with that K04. Why did you buy a 5 bar fpr?
    My 5-Speed Swap DIY
    - B6 USP
    Oct 27 2006
    Fargo, ND
    Price you paid for each item please
    Some programs require a 5bar FPR
    2008 Honda Pilot SE
    Nov 27 2006
    Quote Originally Posted by biketsai View Post
    I'm most likely going to go with the GIAC K04 tune, which requires the 5 bar FPR:
    http://giacusa.com/programs.php?mpid=55
    Hooray for boobies!
    Senior Member Three Rings PoormansA4's Avatar
    Mar 26 2009
    Wildomar,CA
    you could just buy the TIP from 034 or even if you add $250 still quite a bit cheaper than 034s kits
    For sale
    wiring harness 01 1.8t
    map sensor
    stock injectors
    fuel rail
    stock FPR
    brand new front and back rotors (quattro)
    Nov 27 2006
    Wink Re: Best Turbo Solution for Tiptronic for under $3K
    $700 for the K04 off a fellow audizine member
    $350 for the intercooler - ebay special, hopefully it works ok see here
    $80 for the 5 bar fpr from 034 motorsports
    $90 for the 034 DV
    $139 for the guage and pod from PODI
    $45 for the gasket/hardware kit from 034
    Hooray for boobies!
    Mar 26 2009
    Wildomar,CA
    that IC seems a bit big or is that just me
    For sale
    map sensor
    stock injectors
    fuel rail
    stock FPR
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by PoormansA4 View Post
    If anything, its small. 1.75" piping?!
    My 5-Speed Swap DIY
    - B6 USP
    Nov 27 2006
    small piping for a small turbo... I figure with as little as the K04 is pushing out it should be adequate, at least I hope so.
    Hooray for boobies!
    Mar 26 2005
    2.25in would be more adequate, especially if you plan to run the aggressive file that giac offers.
    TEAM|AXION
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    Tempting, and a good price and everything, but i would avoid that kit because of this
    " Note. The B5 A4 kit(Model Years 1997-2001) is only available with the ATP/Mika tuned software. "
    Word on the street is that mika sucks ass
    {99.5 Avant}
    Mar 26 2009
    Wildomar,CA
    o was talking bout core, lol didnt really read sizes
    For sale
    map sensor
    stock injectors
    fuel rail
    stock FPR
    981CGTS, Cayenne Turbo, Escape, Passat
    Chicago 'burbs
    If you are piecing together a kit. I may have the software for you as well as most of the other things you might want.
    K04, software, cat, downpipe, (manifold sucks but would be thrown in with turbo), 180 tt injectors, a real Bosch Motor sport 5 bar FPR, even a trans valve body and exhaust. The Racetech would have been nice, but that was the only thing I didn't have.
    Quote Originally Posted by DGAFxxx View Post
    2014 A4Q Red w/ black optic black interior
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    or you could just sell your car for probably 4-5-6k throw down your extra $3000 and buy and s4 or a built a4?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Now only if there was a place where people could get parts cheaper.
    Jul 07 2004
    socal
    Quote Originally Posted by Jibberific View Post
    Revo has tuning for the 2001, for the 97-00 people can just go with all the same parts but go with Uni and 415, 440 or 630 injectors. No one should even be touching the Mika software any more. That Kit from Eurocode is now sold with 550cc injectors which they sell for $2999.
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    a 240..... man i eat those things with a k03..
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Nov 27 2006
    Can anyone chime in with their thoughts on upgrading to a level 10 valve body? Is this necessary? or will help prolong the life of the tranny?
    Hooray for boobies!
