Results 1 to 7 of 7
    Registered Member Two Rings
    Apr 28 2004
    Las Vegas
    amp remote turn on wire
    which wire from the factory radio harness(what color?)
    can I tap an amp remote turn on to? Turn my radio on when I put the key in.
    I don't have a multimeter at the moment. I want to make sure I got the right wire.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    you dont need a multimeter...to to lowes and buy on eof those 3 dollar test lights....it will take all of 2 minutes
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    pull it from the fusebox buddy.. the stock harness does not provide enough power to run a remote amp turn on wire from.
    Registered Member Four Rings Vortec4800's Avatar
    Oct 10 2004
    2005 A4 1.8T
    Phoenix, Arizona
    Or just run it to a relay. Then you won't have to run a wire all the way from the fusebox to the back. Plus the fusebox won't have a signal that turns on with the radio, you'd just have an ignition wire.
    Feb 13 2004
    Chino Hills, CA
    or u could tap into it from the stock amp in the rear sidewall
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    yeah jeff i have a relay =P i cant believe i forgot what its called for like 10 minutes the other day hahaha
    do what jeff said.. tamp the remote turn on at the factory amp.. its right there in the trunk easy to find too..
