Results 1 to 4 of 4
    Apr 20 2009
    Orange County, CA
    Security code on head unit?
    I have 2007 RS4 with the RNS-E Nav Unit. I am going to install an amp soon and need to disconnect the power. I got the car used and have no idea what the security code is for the headunit, if there is one at all.
    Does this head unit require a security code after power loss??
    Registered User Three Rings 05.5SilverS4's Avatar
    Jun 14 2009
    2005.5 S4 , 2000 Yamaha R6
    Fishers, IN
    Re: Security code on head unit?
    I dont have the RNS-E unit but i know if it does require the code it will be in your owners manual set, i believe in one of the supplements. Check there before you disconnect, or im sure a call to AOA will help you out too.
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    If the code is not in the manual, I know you can let it get read out over the vag com connector at your beloved Audi dealer. Properly will cost you.
    2002 A4 3.0 Quattro Manual
    Active Member Two Rings Titanp321's Avatar
    Mar 15 2009
    06' B7 2.0T Tip
    Boston
    don't hold me to this but I have taken out my RNS-E head unit with no problems of the security code being triggered. The condition I followed: I never turned the car on while the radio was unplugged. I have removed the head unit a few times now with no problems.
    I had really wanted my code, just for safety of having it, so I brought the audi in for a "loud noise in the rear end" under warranty and asked if they could pull the RNS-E security code while they had the car hook up. Of course, there was no noise and I got a my code.
    Ryan
