Page 2 of 2 FirstFirst 12
Results 41 to 80 of 80
  1. #41
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Re: Stainless Steel Pedals
    I just bought the RS4/2008 S4 pedal set for my 2007 S4.
    Dead pedal
    Clutch
    Brake
    Accelerator
    $195 shipped from Germany. ebay.de seller
    $300 is a bit steep! Here's the seller I bought from
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
  2. #42
    Mar 05 2009
    Earth
    Quote Originally Posted by sakimano View Post
    Dead pedal
    Clutch
    Brake
    Accelerator
    Looks like a good deal....I would be curious what the final bill is after exchange, shipping, duty, brokerage fees and whatever other random thing they can slap on.
  3. #43
    Oct 08 2009
    A4 B8 3.2 Quattro Sedan
    Hong Kong
    i ordered mine as well, but im still worrying if it can fit on my B8 or not, cause i checked my gas and brake pedal last night, i think its a little bit different.....?
    2008 A4 (B8) Sedan 3.2 Quattro Tiptronic, Ibis White
    19" Work Varianza F2S / Eibach lower spring / Ceramic Tint / D3S 6000K HID head light / Xenon 6000K fog light / LED Liscense plate light / LED interior light / Smoked tail light / Blackout grill, rings and debadged / ABT rear valence with custom quad tip exhausts
    VAG COM : Needle sweep, Full LED brightness, Day time running light, Lap Timer
  4. #44
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by j.z.c View Post
    Just remember, the brake pedal cover gets replaced, while the gas pedal stays as-is and the aluminum cover just slips over and is a SUPER tight fit. At first, I thought for sure mine wouldn't fit but kept working at it until I got it on there.
  5. #45
    Oct 08 2009
    Hong Kong
    thanks Blake.
    so you mean the brake pedal needed to take away the stock one and replace with the RS6 one right?and the gas just slips over on the stock one?
  6. #46
    Oct 08 2009
    Hong Kong
    and Blake, by the way i dont know why my dead pedal is different from yours, cause mine is narrow shaped from top to bottom, that's why i didn't order the whole set but the gas and brake, so you think the gas and brake pedal would probably fit right?
  7. #47
    Mar 02 2007
    Fresno, CA
    thanks Blake.
    That's exactly right. Why not post a pic of your pedals so we can see if they're any different from other B8's.
  8. #48
    Active Member Two Rings Wildcat216's Avatar
    Jan 29 2010
    2010 Audi A4, 2010 Ford Fusion SEL
    Norman, OK
    I finally got my RS4 pedals in from Germany (ebay for about $190). I got everything on with just a little effort except the clutch. Gas, brake, and dead pedal went on easy. I've been at the clutch pedal for about 2 hours now and have finally had it. Does anyone have any tricks they used to get the clutch pedal on????
  9. #49
    Veteran Member Three Rings dirtysoil's Avatar
    May 23 2009
    23 Tiguan; 22 RS5; 18 SQ5
    Indpls, IN
    Quote Originally Posted by Wildcat216 View Post
    Don't laugh, because it works.....KY water-based lube. Spread on all contact edges (pedal and new cap) in very small amounts. Start at the top and work your way down. It also helps if the rubber is warm and pliable.
  10. #50
    Jan 29 2010
    Norman, OK
    Well, at this point I will try anything, even your sex jelly. haha. I thought about heating the rubber up, too, but I figured it would cool before I could get it on. Maybe I will wait for a warmer day if the lube doesn't work.
  11. #51
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    Is this the only blot on replacement pedal available?
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
  12. #52
    Apr 15 2010
    For anyone who is interested i just found this website who has the pedals (set of 3) for almost $100 cheaper than ECS and the dead plate for $70 less.
    http://www.tmtuning.com/audi/
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
  13. #53
    Active Member Two Rings Purbina's Avatar
    Feb 02 2010
    Miami
    Do you guys think the Rs4 Pedals will work on a 2010 S4?
    2010 Meteor Gray S4
    Rear Differential, 19" Tri-Spokes, Navigation
    Stratmosphere Intake, Milltek Exhaust
  14. #54
    Established Member Two Rings johntnethk's Avatar
    Aug 24 2009
    '09 A4 2.0t AWD, '11 G37S
    Should be the same pedals as the A4, so yes.
    APR Stg.1/EuroCode Quadtips/EuroCode HFC/KW V1/StaSiS RSB/VMR 710 19x8.5+Hankook EVO/OEM Black Optic Grill/OEM Blk Plate/OSIR CF Splitter/OSIR CF Valence/Rieger Spoiler/RS6 Steering Wheel
    Shipping: OSIR CF Side Sills, RS6 Pedals
  15. #55
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
  16. #56
    Jan 29 2010
    Norman, OK
    Quote Originally Posted by dirtysoil View Post
    got it!now what to do with all that extra ky...
  17. #57
    May 23 2009
    Indpls, IN
    If you really need to ask, then you should just throw it away!!!! So did the lube work out for you in regards to installing the pedals?
  18. #58
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    Can somebody confirm pedals for 2010 A4 tip
    Looks like i want RS6 2008+ Gas, Brake and Dead pedal (easier to install the RS4)
    http://www.tmtuning.com/HOME/catalog...t_product=2662
    2010 A4 Avant
  19. #59
    Mar 05 2009
    Earth
    Quote Originally Posted by Toast View Post
    yes, you need the RS6 kit. The RS4 dead pedal is the same but since the RS4 was only available in manual obviously the others (gas, brake, clutch) won't work.
  20. #60
    Nov 06 2009
    If you went to the DIY I posted you'd have confirmation and the part numbers you need for the TIP....
  21. #61
    Veteran Member Three Rings Comp4k's Avatar
    Aug 10 2009
    Carlsbad, CA
    OEM Plus now has access to the RS5 pedals, I'm still waiting on pricing from them- but it may be easier to install than the RS6 set.
  22. #62
    Nov 06 2009
    Looks like it wont make a difference for install. They are still using the old style dead pedal.
  23. #63
    Active Member One Ring pns2007's Avatar
    Feb 06 2010
    Shropshire - UK
    Just received my set of RHD Aluminium pedal covers and thought I'd update the thread with my experience.
    My current pedals on my RHD MY2010 A4 look like this (minus the rubber covers):-
    The Aluminium pedal covers which I have received look like this (next to the old rubber covers)
    On my car the clutch pedal is slightly smaller than the break pedal, however both new aluminium pedal covers are the same size. They should fit though!
    However, the gas pedal on my car appears to be the same as the LHD car but the Aluminium pedal cover is alot smaller and tapers at the top. I think I may try and see if I can swap it for a LHD pedal cover as it looks as though it may fit!!
    I also ordered the dead pedal and gave the part number over the phone. I received this :-
    although on the box the part number stated is 8E2 777 B4P7, so I think they gave me the wrong one. Anyway they have given me a refund.
    Anyone had any experience of fitting new pedals on a RHD car?
    Are the original brake and clutch pedals the same size or is the clutch smaller like mine?
    You will no doubt see that my dead pedal is a totally different shape to Wolfs9's dead pedal.
    Any info would be great.
    Parts obtained - 8E2 721 891 (Gas), 8E2 721 989 (Brake) and 8E1 721 647 (Clutch)
  24. #64
    Apr 16 2010
    Montreal
    Got my pedals today!!! but still no car :(
    only getting it end of june!
  25. #65
    Jan 28 2010
    bunch of tools and bicycles
    Dallas, TX
    Anyone have pictures of what the RS6 pedals look like with tan interior?
    2013 Audi TT Brilliant Red
  26. #66
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    the cars is not even 24hrs old and already got the skirt and pedals, I love it!!!!!
  27. #67
    Senior Member Three Rings c99's Avatar
    Feb 28 2009
    RS5 2.9TFSI - dead engine
    EU, CZ
    I use RS5 dead pedal, which fits perefectly to A5 and A4 also. RS5/RS6 gas pedal, RS4 brake and clutch pedals.
  28. #68
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    Quote Originally Posted by c99 View Post
    thas true i used the rs6 dead pedal on my tip b8 and it fits way better than the rs4 dead pedal.
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
  29. #69
    Feb 28 2009
    EU, CZ
    But RS5 dead pedal has no hole for a screw, like RS6 has.
  30. #70
    Active Member Two Rings jfive1029's Avatar
    Mar 23 2010
    So Cal
    Where did you purchase the RS5 dead pedal from? Can you provide a link?
    09 Audi A4 2.0T Prestige S-Line Quattro Tiptronic - Ibis White
    APR Tuned Stage I ECU, Vag-Com'd, Reiger Spoiler, K&N Air Filter, Black Calipers w/Audi Rings, Gloss Black Plate Delete,Touchscreen Nav, DVD, DTV, Reverse Cam, Hoen Fogs, Interior+Plate LED Bulbs, Rear S-Line Badge, OEM Gloss Black Grille, VentureShield Clear Bra, OEM All-Weather Mats, Tinted E-Codes, RS5 Pedals + Dead, S tronic Gear Knob, Posi Quiet Brake Pads, Drilled Black Rotors
  31. #71
    Feb 28 2009
    EU, CZ
    From Audi dealer.
  32. #72
    Mar 23 2010
    So Cal
    From Audi dealer.
    Yikes! How much did it cost you at the dealers?
  33. #73
    Nov 06 2009
    It's not nice to ask people to relive traumatic experiences
  34. #74
    Aug 10 2009
    Carlsbad, CA
    Quote Originally Posted by DavidB8 View Post
    Hahahahah.
    I need to find a RS5 dead pedal as well, can't seem to find any on ebay.de.
  35. #75
    Mar 23 2010
    So Cal
    Too funny, I know right!
  36. #76
    Nov 06 2009
  37. #77
    Senior Member Two Rings S4Tokyo's Avatar
    Jun 16 2010
    Tokyo
    Autos use RS6 gas and brake pedals.
    Manuals use RS4 gas and brake pedals.
    Both use RS4 dead pedals and require swapping the black rubber base from your stock dead pedal to the RS4 dead pedal and cutting a slot in the rubber for the extra prong to slide through and tighten. It's pretty obvious once you've got them in front of you.
    Following w/much interest. Have RHD car but have understanding that there is no specific kit for RHD (not sure why). That being said, the pedal set is not symmetric between LHD & RHD but trans-positioned (across car centerline) ...or would it not be? Can anyone share / suggest why LHD kit would not also fit RHD car? For dead Pedal might it be that there is different side wall on LHD side of car V's sidewall on RHD - the latter of which is set up against centre tunnel? TIA.
  38. #78
    Jun 02 2009
    San Francisco
    Quote Originally Posted by S4Tokyo View Post
    The pedals would be in the same position no matter if it is LHD or RHD.
    Dead pedal on the drivers left, brake pedal in the middle, and gas pedal on the right.
  39. #79
    May 16 2009
    Maine aka Canada Jr.
    positions are the same yes... but the tunnel over the transmission isnt even on both sides so the dead pedal is smaller in RHD cars. and due to the closeness of the accelerator pedal to the right i believe it is slightly smaller...
  40. #80
    Jun 16 2010
    Tokyo
    Thx. I guess that's the issue so, seems I was on the right page, just needed to confirm w/someone else. I was told I can use the LHD Accel & Brake pedals for RHD but not the Dead Pedal......it was suggested to use RS6 pedal w/some significant re-work to fit S4 - now I understand better as to 'why'?
