Page 17 of 17 FirstFirst ... 7151617
Results 641 to 656 of 656
  1. #641
    Veteran Member Four Rings ChicagosPhantom's Avatar
    Aug 28 2013
    02 Nemo S6 (stolen) / 03 Silver A6 2.7T K04 01E / 03 Daytona RS6 / 04 Dolphin A6 2.7T 01E / 02 Silve
    Chicago IL
  2. #642
    Jan 10 2015
    Colorado
    Thanks.
  3. #643
    Jan 10 2015
    Colorado
    Sounds great! V8 though, wonder how similar the 2.7T would sound. Is that yours, and what's the setup? Strike that - just saw I could expand the info under the vid to see the setup.
  4. #644
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by Fayston View Post
    Similar or same setup on 2.7 will sound good too, Xpipe is a must on V6...all videos on that channel are from my very own cars, as you already saw description is in the video.
  5. #645
    Veteran Member Four Rings jolio1994's Avatar
    Sep 06 2011
    Little Egg Harbor, NJ
    Ah, may as well.
    Compilation of my RS6. Let's see... Stock downpipes with fully gutted downpipes and a 2.5" catback with nothing stopping it.
  6. #646
    Jan 10 2015
    Colorado
    Quote: "Ah, may as well."
    Why wouldn't you!
  7. #647
    Jan 10 2015
    Colorado
    Pulled the trigger on that setup; Wagner downpipe - 3", Magnaflow catback - 2.5". Both are designed to bolt on to stock, so are reduced to 2" at the downstream and upstream ends respectively - seems restrictive at that point (although necessary if mating to OEM). Plan is to replace the 2" sections with 2.5". Final setup will be 3" downpipes and 2.5" catback. Work should be done next week.
    > High flow downpipes: https://www.ecstuning.com/b-wagner-t...500001001~wgt/
    > Magnaflow cat-back https://www.magnaflow.com/products/1...exhaust-system
    Stage 1 tune (by Stuklr), stock turbos (K03's); look forward to seeing if/how this affects the seat dyno, sound, temps, etc. Anyone have an idea of what to expect?
  8. #648
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    no pictures or video yet but I did an xspower turboback but found it to be far too quiet so I cut out the rear mufflers and left the center resonator and now I love the sound
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
  9. #649
    Jan 10 2015
    Colorado
    Post video! Were you running stock exhaust before this?
  10. #650
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by ChicagosPhantom View Post
    Did you put those Ultra-quiets where the stock mufflers would go?
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
  11. #651
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by Bordom View Post
    Correct.
  12. #652
    Jun 19 2020
    Charlotte, NC
    Correct.
    How is the noise inside while driving?
  13. #653
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by talleyrand View Post
    There's zero drone, it's perfect actually, wife had zero complains, only compliments.
  14. #654
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    can some please let me know if a muffler delete on a stock A6 2.7.t will cause any drone?
    Am I better off deleting the mid resonator and adding some S6 oem mufflers?
    trying to go as load as possible without having any drone.
    thanks in advance
    2007 RS4
    2000 B5 S4 stage 3
  15. #655
    Senior Member Three Rings Jawsman2's Avatar
    Aug 06 2020
    2007 Buell XB12scg, 2002 Mercedes E55 AMG
    Redmond, WA
    2002 Tectite Grey/Black E55 AMG Kleemann K2 N/A Kleemann headers/downpipes ecu tune/ x pipe, secondary cat/resonator delete, Supersprint muffler/ H&R/Bilstein
    2007 Buell XB12scg Cherry bomb
    Work email:
    [email protected]
    IG: Jaws.Garage
  16. #656
    Junior Member One Ring
    Aug 25 2019
    93 Corrado Vr6
    Buckingham, Qc
    that some nice sound.
