so i was having my car checked at a shop for a coolant leak and they said that a bunch of hoses and valves need to be replaced. so i have been doing some research and found info on some of these things. they gave me the P/Ns below as a "bare minimum" i should change out, but recommended i replace the whole breather system. i was changing my valve cover gasket and got a look at a couple of these, they had gotten oil on them from the leaky valve cover gasket and i was told this caused corrosion in some of the hoses. i found this diagram http://forums.audiworld.com/picture....ctureid=190539 and read through the DIY on vacuum lines and check valves , but it doesnt list all the components (need name/P/N), plus i think its for a different engine. i think these things i can probably replace myself and save several hundred dollars they wanted to do (around 220 for the parts and 300+ for labor).
N-904-673-01
06A-103-213-AM
06A-103-247
06A-103-245-F/C
06B-103-213-AF
06B-103-221-L
06A-133-528-D/A
basically what i want to know, would damage to these hoses/valves affect performance of my car. it appears that the crankcase bleeder valve needs to be replaced per the list of P/Ns, although i havent seen it with my own eyes. can someone please post a bentley image of the crankcase hose system with the component names and P/N's, it would be a tremendous help to me trying to work through this. thanks in advance.
car: 2004 1.8t quattro tiptronic stock, 41k miles
