Originally Posted by
JDM EJ1 95
being that the block is made out of aluminum doesnt mean that it cant handle power.
thats just a stupid statement. some of the best high hp motors are aluminum.
example... LSx motors can handle quite a bit of power boosted or not.
I didn't say that, did I?
The LSX is actually a cast iron block.
http://www.gmperformanceparts.com/En...6454&engCat=ls
If you were talking about the aluminum LS1,2,3,6 etc, that's a totally different ballgame. Those are aluminum blocks with cast in iron sleeves. An LS1 can't handle more than 600 hp reliably on the stock block, and that's spread out over 5.7 liters of displacement. Any more and you end up sleeving the block which is not an option on the Audi engine.
Guess what the bore to bore spacing on the 3.0 is versus any of the LS engines? It's a whole lot smaller, but you probably didn't think about that.
GM uses cast iron sleeves and Audi doesn't. You probably didn't think of that either.
A rather well known Audi tuner has tried to build a boosted 3.0 block and it was a huge failure, but I bet that didn't cross your mind either.
Even comparing a large displacement V8 to a small displacement V6 is what I would call a stupid statement. The construction is totally different and the loading is obviously different.
audimeister
Er, I had a 944 turbo with an aluminum block that went pretty well...
And that relates to the Audi block how????
You can
design an aluminum engine for a boosted application, that's what Porsche did. However when you take an aluminum block that wasn't designed for boost, that's just asking for problems.
