Page 8 of 9 FirstFirst ... 6789 LastLast
Results 281 to 320 of 350
  1. #281
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    P0089 is a generic code. Scan with vagcom to get the real codes.
  2. #282
    Jul 04 2013
    san diego california
    Ok update, today i replaced HPFP and thrust sensor, NO start, but scanned again just to see if there's still only one code like before, and there's a new one P0321- Crank sensor/speed sensor, so i'am pretty sure that's why it doesn't start right now... hope that's the last thing xD
  3. #283
    Senior Member Two Rings brew_daugus's Avatar
    May 28 2013
    PA
    Is there a DIY for the thrust sensor g410 anywhere?
  4. #284
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    Quote Originally Posted by brew_daugus View Post
    It is literally right on the hpfp. You just need to disconnect the electrical connection to it and use a open ended wrench to remove it
    Sent from my Nexus 7 using Tapatalk
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
  5. #285
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Look here for some info on the G410: http://forums.vwvortex.com/showthrea...l-system-issue
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
  6. #286
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Like stated above the trust sensor is probably one of the easiest things to do on the car! Anyway I hope that fixes your problem! Glad most of your codes are gone OP
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
  7. #287
    Jul 04 2013
    Update... the code is gone (po089) but there's still a failure, every time when i star the car and drive it for 5 mins aprox. low rev. 1500-2500 the car some times start failing and shut down, or just failing for about 10 segs. not letting me rev up, then the car works just fine. No check engine code... Not sure if it a gas or spark issue...
    (new fuel filter, new cam follower and HPFP, new electrical fuel pump, and good spark plugs)
    What else i'am missing...
  8. #288
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by HEMI HEAD View Post
    Did you check your air filter? Or intake in general? If it is getting enough fuel but not enough air it could be bogging down. Just an easy suggestion, always check the easy things first IMO.
    Any codes?
  9. #289
    Active Member One Ring LittleRedA4's Avatar
    May 29 2014
    2012 Volkswagen Jetta SEL Premium (Heavily modded)
    Cooper City, South Florida
    Quote Originally Posted by Grishbok View Post
    P0089 Fuel Pressure Regulator - Performance
    This code is stored in my ecu and the cel is on. My question is, who else has taken their car in for this? My car only has 20k miles on it, so it better not be a cam issue.
    Im getting that code but no light. Just changed the timing belt and water pump. I go to put the car in reverse and it started jumping around. A bit of a loud clicking. Engine isnt shifting itself back and forth correctly. The timing belt is done right. So I dont know what is going on at all with my car. No check engine light. No CEL light. Just the code p0089 on the OBD II that says its pending.
    Help...
  10. #290
    Senior Member Two Rings bryonm's Avatar
    Jun 02 2013
    Mililani, Hawaii
    Everytime I get this code I simply just erase it. I've done all that has been said about this code and it still comes up. It's like chasing a damn ghost, plus whenever it comes on the car doesn't act any differently
  11. #291
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Finally replaced my lpfp with oem and all lights are gone. P0089 hasn't come back in days.
    2021 Audi S4, P34 Intake
  12. #292
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    P0089 is a herpes code which you can NEVER get rid of. It will come back again, it's just a matter of time. But you can suppress it longer to the point where it doesn't have to come back by making sure the surrounding parts/sensors (G410 thrust sensor, lpfp, hpfp, fuel rail, etc..) are cleaned and up to date. Yeah, I sound like some sick doctor/mechanic hybrid. Did you check/replace the G410 Thrust Sensor? That did it for me as of now.
    Quote Originally Posted by bryonm View Post
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  13. #293
    Jun 02 2013
    Mililani, Hawaii
    Quote Originally Posted by 80sGuy View Post
    I haven't tried the thrust sensor yet, I suppose I'll try that sooner or later
  14. #294
    Dec 03 2008
    2018 SQ5
    This code can literally be caused by ANYTHING related to the fuel system. And there is absolutely no way to differentiate between the causes through symptoms. The only way to fix it is to start replacing EVERYTHING one by one starting with the cheapest part. Just hope it isn't the last thing you can possibly replace that fixes it. That sucks, ask how I know.
  15. #295
    Oct 09 2007
    Miele S7
    No reason not to at this price.
    http://www.europaparts.com/thrust-se...6e906051k.html
  16. #296
    Oct 09 2007
    Miele S7
    I almost forgot to mention that Audi has extended the warranty to 10/120 for parts associated with the P0089 code and the Thrust Sensor is one of them. Check with your dealer to see if you qualify for what needed to be replaced - free of charge.
  17. #297
    Dec 03 2008
    2018 SQ5
    Yep, that Sensor is the cheapest thing to start with, second being the fuel filter.
  18. #298
    Veteran Member Four Rings Unit1Evangelion's Avatar
    Oct 10 2009
    Rogue gym equipment and tools to make me feel manly.
    Texas
    Mine is popping again. I have replaced,
    HPFP
    Cam Follower
    Cam Intake
    Thrust Sensor
    LPFP - twice
    Fuel filter - twice
    Cleaned fuel system - 3 times
    My car was working great until I brought it in to get the Cam Follower replaced and such. Ever sense then, my LPFP has been going out again. Delayed startups, low end bogging, CEL (P0089), and rough idle. Wtf? Why is the LPFP a constant failure?
    "What you do in life, echoes in eternity."
  19. #299
    Aug 30 2013
    Try doing a fuel adapation, maybe it will help.
  20. #300
    Dec 03 2008
    2018 SQ5
    Lpfp controller possibly. That's the only thing it looks like you haven't tried.
  21. #301
    Senior Member Three Rings Roaldtm's Avatar
    Jul 20 2014
    Martinez / Georgia
    Got this dreaded code today... the Bluetooth and torque app say P0089 and when I got home and ran the Uniconnect(the car is Unitronic Stage 1) software it says P0130B. The car has 77,890 miles and the engine was replaced 5,000 miles ago, I replaced the fuel filter 3,000 miles ago an the new engine came with a new (or re manufactured) HPFP. What should I try first? the N80 valve?
  22. #302
    Mar 13 2012
    Cambridge, MA
    Sorry. Sell your car (preferably to the dealer as it's the quickest way to wash your hands from it) and buy another car. Life is just too short to deal with this issue. I spent four months and 20 hours of my life on it before giving up and moving on. Your time is valuable.
  23. #303
    Dec 23 2011
    You wrote P130b but if it's the P310b code and that was a typo then it means the lpfp system pressure is out of the expected range somewhere between 3-6 bar). That is usually ties back to the lpfp itself or the lpfp control module. You can log the low fuel system pressure to see if it is too high or too low and then start replacing parts later.
    TBH after months of trying to fix this code I just disabled it in maestro as my low pressure fuel rail was always between 4-6.5 bar and it hasn't caused me any problems.
  24. #304
    Oct 09 2007
    Miele S7
    Replace the G410 (Thrust Sensor). Cheap and easy fix and it worked out for me when I got the code back in Oct 2011. Knock on wood, but hasn't seen it since!
    http://www.ecstuning.com/Audi-B7_A4-...News/ES251666/
    Quote Originally Posted by Roaldtm View Post
  25. #305
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Worth a shot, but that didn't fix it for me. I think mine is crud in the tank related. After replacing the G410 sensor, I discovered that the gasket around the lpfp disintegrated and bits of it got sucked into the fuel tank and I haven't had a chance to clean it yet.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
  26. #306
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by billyhoyle View Post
    This was what caused mine, sediment in the fuel tank. Went through 3 lpfp to figure this out. Had three code for near 2 years i think.
  27. #307
    Jul 20 2014
    Martinez / Georgia
    Thanks for the input guys, I'm so damn frustrated with this car by now... So far after I cleared the code yesterday it hasn't come back, lets see how long it stays off.
  28. #308
    Dec 03 2008
    2018 SQ5
    Don't lie to yourself. Lol. This is one code that definitely doesn't go away on its own.
  29. #309
    Dec 23 2011
    This.
  30. #310
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by p0isin View Post
    This.
    Lol, it only gets worse. I too once thought it must have been a fluke. Until it started coming up within minutes of clearing it every time.
  31. #311
    Jul 20 2014
    Martinez / Georgia
    Sh!t I just don't want to throw money at this thing anymore.
  32. #312
    Veteran Member Three Rings ElectroMike's Avatar
    Apr 17 2009
    2014 S4 M/T
    Exit 160 NJ
    I'll join this club.
    Two weeks ago car would not start on the first try, cranked but would not turn over, I gave it a few seconds and it started up, for the next week it would take a split second or two longer for it to turn over.
    Last week I got the P0089, cleared it, 10 miles later after a cold start, same code, cleared it couple of more times and decided to bring it in to my local shop. All pointed to the Fuel Pressure Sensor, no biggie, it was replaced. As the mechanic goes for a test drive, CEL lit up for him, he digs further = LPFP is a goner (70K miles on the car). Replaced it, been riding about 3 days straight, starts quick again and knock on wood no CEL.
  33. #313
    Jul 20 2014
    Martinez / Georgia
    How hard will a LPFP replacement will be? I'm just curious in case mine is toast.
    Sent from my HTC6525LVW using Tapatalk
  34. #314
    Jul 29 2010
    Calgary, Alberta
    Easy peasy. The hardest part is getting the damn fuel lines to come off the top of the pump if you don't have the special pliers. Make sure your tank is as close to empty as possible before attempting it.
  35. #315
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Quattro? Easy.
    FWD? Even easier.
    There are threads detailing the job.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
  36. #316
    Jun 17 2013
    jersey city nj
    I had the P0089 code pop back up a few times again under WOT while hard. So I the lpfp A4 fuel pump control unit with RS4 control unit and the P0089 code never popped back up again. Guess if your tuned or KO4 & it makes the stock A4 unit max out on the duty cycle and trigger the cel.
  37. #317
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Quote Originally Posted by vce1232000 View Post
    Yes, that exactly seems to be the case...Seems like the LPFP CM might actually be more to blame than the LP fuel sensor on the HPFP?
    Returnless fuel systems are computer controlled and the fuel pump output and actual fuel rail pressure is determined by a fuel pressure sensor on the rail that uses the temperature of the fuel to determine the actual pressure. The Powertrain control module or Engine control module (PCM/ECM) has determined that the fuel pressure commanded is not within specifications and will set the DTC P0089.
    As for me, I looked over this thread for YEARS but would happily walk on by because I never once got this error code...Welp, things have changed
    Code:
    p0089
    valve for fuel metering
    n290
    implausible signal
    I've been pushing my car super hard for the past 2-3 months but it never triggered it until now. I did 2 or 3 REAL hard pulls a few days ago and just wanted to make sure no silent codes (cuz no MIL) came up...Well clearly they did. I know the N290 is actually the LP fuel sensor on the HPFP (thrust sensor?) and I got that replaced at my local dealership 2 years ago under the extended warranty. As well, like last week I replaced my cam follower and both it and my HPFP were in perfectly fine shape. Have replaced my fuel filter and LPFP control module within the last 15k miles as well
    No side effects so I just cleared it and it better not come back or else I'll have to really investigate...Probably with freebies like checking to make sure I screwed the thrust sensor back on tightly enough, all the fuel lines going to the HPFP are in good shape, etc.....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
  38. #318
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    Do any of you guys know how long does adaptation for block 103 take?
    I left my car idle for 30mins and only the last column on the right hand side got aan adp.ok sign. The other just kept up and downing the value and wont adapt.
    Thanks
  39. #319
    Oct 24 2015
    Perth, WA
    Ok so this is the 6.6 bar fuel filter, can someone tell me what the 3rd small nipple is on the left hand side?
    My respray thread
  40. #320
    Dec 19 2012
    Europe
    Where did you read that might solve our issue? What is the price and part number of that filter?
    I'd buy 3 right away if it actually cleared your p0089 code
    Quote Originally Posted by Okedokey View Post
