Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
Hybrid View
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    good gawd... that looks awesome, what does a detailer charge for something like that ?
    beautiful car man, perfect drop too
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Veteran Member Four Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    Quote Originally Posted by TarlCabot View Post
    Thanks! It wasn't a full car detail, although the whole car was polished and sealed. This job was mostly for the hood damage and was around $350.
    Sep 05 2008
    Northwest Florida
    So I raised her. Had to.
    After a flat earlier in the year, it was time for new tires. Went to 245/35s from 235/35s with the proper load rating. It is my daily driver after all.
    Also had curbed one of my peelers late last year, so I had an excuse to lose the Avus spare ...
    Dec 07 2009
    East Coast
    And it still looks great
    Any rubing with new tire setup and what's your ftg?
    Forget the B8, keep the V8!
    Sep 05 2008
    Northwest Florida
    Quote Originally Posted by Mr.Wrong View Post
    At the old ride height (about 24⅝" all around) with 245s it was rubbing over the slightest bumps. Now after raising the car up to around 25½" front, 25¼" rear (yes, slight reverse rake—it's actually better for weight balance), the ride is slightly better, and the car has noticeably even more grip. It feels fantastic.
    Sep 05 2008
    Northwest Florida
    Swapped out my center console today!
    Did not go B7 though as I had found a great condition B6 one for cheap. Now that I have this experience, I may go for the swap later.
    Just realized I don't have a pic of the new one installed. Looks the same anyway.
    Dec 07 2009
    East Coast
    Thanks for that info man. Where did you find a deal on B6 center console? I'm thinking of replacing mine due to some minor wear and I'm sticking with B6 one as well. I don't have the need for B7 cup holder comfort.
    Sep 05 2008
    Northwest Florida
    I just managed to find it on eBay. Don't buy unless they take good photos!
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    looks good as always.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Jan 24 2010
    norcal
    yyour car looks amazing! i'm currently looking for some s5 wheels too for my b7
