Background:
My RS4 is currently at the dealer for them to investigate the second occurrence of a multiple misfire MIL(possibly at least the third from before I owned it). I have read the following thread (http://www.audizine.com/forum/showthread.php?t=270388, and all of the linked and similar threads) that I could find about the FSI oil deposits in heads / on valves issue, which indicated that when it is getting bad you will get misfire MILs (although I am not sure at what frequency, variable I guess). I have posted my vag output for the two that I have recorded below. I bought the RS4 with almost 38K mi, so whatever is wrong has been wrong since I bought it (these codes were in the ECU when I picked it up, I scanned it before I actually bought it). I do not know if it has been having this issue longer... the service history does not show any specific MIL codes reported, but then the history is very high level / sparse. The only related thing I see is that they replaced the fuel pressure sensor as part of the CPO as per TSB. I do not know if there were issues (like MIL misfires) that caused them to perform the work in this TSB, or they did it because of a recall as my service writer said is possible.
Questions:
Does anyone know if there is a TSB attached to a recall including replacing the fuel pressure sensor for the RS4?
What exactly triggers a misfire MIL? I am used to ignition/fuel system problems causing misfires, but cannot think through how deposits on valves can cause misfires, especially since the injectors are in the cylinders (hence very small possibility for injector blockage).
Are there any other relatively non-invasive ways to figure out if the valve build-up is the cause of the MIL? I guess I am trying to figure out how to determine if this is truly the cause of the MIL or if there is a way I can rule it out (the absence of another code for example that would normally accompany the misfires).
Is there a non invasive way that I can get a peek at a valve, or is removing the intake the only way? I was thinking that with a flexible lighted boroscope you could remove a plug, go through the cylinder, up through an open valve to see… but I don’t know if a scope that can do that is even available… I am thinking Mission Impossible kind of stuff I guess… does something like that exist that I could perhaps rent from somewhere?
Also, does anyone know if there is a TSB published to address the valve buildup i.e. an approved Audi service to clean the heads/valves to be performed when multiple misfire MILs have been received multiple times for a customer? My service writer called to say that they think that the buildup is the issue(talking to some Audi tech line), but there is no TSB or similar approved process published for them to be able to clean the valves… so basically it sounds like I have to just ignore the MILs??
Has anyone else stateside had their RS4 4.2 cleaned by the dealer, or any other FSI motor for that matter? If so, what was the tipping point / problem that caused Audi to approve the fix being performed? My thing is that I see that a lot depends on the dealer AofA rep I guess, I read that some have no problems getting DRC replaced when it is leaking, some have to fight tooth and nail and get rejected, I really don't get it. I haven't had a case like this yet so I don't know how my dealer / AofA rep are going to be.
Other than diminished performance, what eventual more serious issues can be caused by this buildup? I am thinking of accelerated wear of the components perhaps due to the weights being imbalanced, god knows what may happen if big chunks of the buildup break off and end up bouncing around in the head or cylinder, are these deposits like rocks in consistency to where they could cause damage if moving about freely (thinking similar to a pulmonary embolism caused by DVT, except the damage by the “emboli” is caused by scoring/mechanical damage instead of blockage/tissue starvation).
My vags(abbreviated for length):
37959 mi:
Friday,27,February,2009,10:18:44:09459
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUARU78E57N900252 Mileage: 61090km/37959miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: --H09--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 02301 444 54128
1 Fault Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 61093 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 34.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.811 V
Readiness: 0010 0100
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 61082 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 18.0°C
Voltage: 13.716 V
000773 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 61082 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 18.0°C
Voltage: 13.716 V
69 75 76 77
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 61093 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 34.0°C
Voltage: 11.811 V
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 61082 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 18.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 61082 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 18.0°C
Voltage: 13.716 V
69 75 76 77
VIN: WUARU78E57N900252 Mileage: 63670km/39562miles
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 63674 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 46.0°C
Voltage: 11.684 V
Readiness: 0000 0000
4 Faults Found:
P0300 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
P0305 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Voltage: 13.589 V
000771 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 769 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Voltage: 13.589 V
000772 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 63606 km
Time Indication: 0
Freeze Frame:
RPM: 812 /min
Load: 26.3 %
Speed: 11.0 km/h
Temperature: 34.0°C
Temperature: 17.0°C
Voltage: 13.843 V
69 75 76 77
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 63674 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 46.0°C
Voltage: 11.684 V
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 63313 km
Time Indication: 0
Freeze Frame:
RPM: 769 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 43.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 63606 km
Time Indication: 0
Freeze Frame:
RPM: 812 /min
Load: 26.3 %
Speed: 11.0 km/h
Temperature: 34.0°C
Temperature: 17.0°C
Voltage: 13.843 V
