Results 1 to 14 of 14
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Question Does an intercooler need a tune?
    I have always wonderd....if you install a an intercooler...will that supercharged or turbocharged application need a re-tune? From what i have read...you basicly just bolt/fit an intercooler up and see gains from then next startup...is this correct?
    just wondering if any kind of tune is needed to see gains from adding an intercooler.
    Thanks guys!
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Does an intercooler need a tune?
    No tuning..you dont get gains from an intercooler. You pretty much prevent the loss of power through heatsoak.
    Sep 14 2008
    What about on a supercharged application that is being killed by inefficency?
    Mar 15 2009
    Manchester UK
    youve also got altered length inlet tracts that will effect lag!
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by anmagro View Post
    on an sc application if you intercool it, the iats will drop a lot which is good. You may drop boost a psi or 2 from the piping and the intercooler, however it will be faster due to the the motor being less heat soaked.
    It shouldnt effect afrs enough to need a retune. only way to truly know would be hook up a wideband.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by RS_Rawli View Post
    he could always run a bypass valve close to the throttle body to help out of boost response. And super chargers don't really lag since they're on a belt.
    Dec 05 2007
    Our turbo cars already have a stock intercooler. There are bigger SMICs such as Tyrol or BoosFactory. An FMIC is just better placement for direct flow into the intercooler vs the SMIC which is more tucked to the side. No tune is needed for an intercooler, just make sure you choose the correct size for your application.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    thats actually a good question, but what I've always wondered about intercooler's is:
    Is the IAT drop worth the restriction and drop in pressure in the system? If I were to route my outlet directly to my IM with a dual nozzle meth injection along the way what would be the outcome?
    I'm probably missing something extremely obvious but I just woke up from a long night and I'm curious
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    ^^ my theory to that would be:
    the amount of water/meth needed to compensate for the lack of an intercooler would most likely be detramental to both power, and long term effects on the pistons/tb/valves etc.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yeah, im pretty sure a dual nozzle w/m setup would work but it just doesnt seem worth it. on our 1.8ts it wouldnt make sense to not run an intercooler, the pipping is gonna have to leave the engine bay to reach the TB on our motors anyways.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Quote Originally Posted by Euro-Tuner View Post
    the problem with that is- the water/meth is only cooling while you are on boost. an intercooler is constantly cooling which helps keep the over all temp of your engine down while driving around and while off boost in between runs.
    if you are trying to build a dyno monster of a car you might be able to do that if you set it up right, but its not practical to drive around with only w/m to cool the incoming air. you would definitely see a power drop by doing this. it would be especially noticeable in the winter time when the air is below freezing.
    Mar 30 2009
    Orange County
    It really depends on application. A supercharger is more likely in need of a re-tune because a supercharger is linear in boost and the addition of an intercooler/piping can cause significant pressure drop and throttle lag. To make up for it, you can always add a touch of timing and lean it out just a tad in the lower rpms to help in that scenario. As for a turbo charged application like our Audi's, the ECU can compensate for the pressure drop by keeping the waste gate closed longer to attain the same boost pressure as it did before the FMIC. It should be noted that a custom tune is typically better than a generic performance tune, but a properly sized FMIC will not require a re-tune yet still show a significant increase in performance.
    R2 Performance
    AUDI/BMW/Porsche/VW
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I guess it really depends on the tune you are running at the time. If the tune is so weak that you dont end up with any timing pull with a SMIC you could use a bit more timing with a FMIC. More timing = more tq/hp.
    Jan 06 2007
    NH
    Quote Originally Posted by ghost6303 View Post
    that make sense, its possible, but only for short term power, not long term reliability.
