Results 1 to 6 of 6
    Mar 15 2007
    2001 A4
    seattle
    058 2.0 stroker guys..
    Anyone know much needs to be shaved off the IM shaft for clearance?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: 058 2.0 stroker guys..
    really?!?!?!?!? SEARCH this has been covered already...go to the projects forum. you`ll find your answer there.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Mar 15 2007
    2001 A4
    seattle
    i did and no one gave a measurement...
    97 A4 2.0TQM
    Rochester, NY
    Which rods? I had to get it cut down to 5.5mm to clear scat rods (this is documented, not sure why you didn't find it in a search)
    Mar 15 2007
    2001 A4
    seattle
    Scat rods. Thanks that's what I was looking for. i must have read over it, I kept finding people just saying it has to be grinded down but no measurements..
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    there was even a thread as recently as yesterday with this info in it
    http://www.audizine.com/forum/showthread.php?t=272446
