Results 1 to 14 of 14
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Need help on a DIY
    trying to install the ECS steering column boost gauge pod.
    How do I run the vaccum line from the engine bay through the firewall, into the cabin?
    Also, what wires am I tapping into so the gauge lights up?
    Thanks
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Need help on a DIY
    To the left of the ECU, there is a little rubber grommet that runs right into the area under the dash. Cut a hole on this grommet and stick the vacuum line through this. Look at your fuse box, find a wire that turns on when your car is on, tap it and ground your other wire.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Established Member Two Rings teeitty19's Avatar
    Nov 20 2008
    98 A4 1.8T FWD
    Michigan
    i ran mine through the hole where the throttle cable comes in (enters the cabin right behind and slighty above the gas peddle). just make sure you dont pull on the throttle cable while doing so, as for the lights just tap into your head light wires coming from your fuse box and ground to whatever you want. there is a little plastic triangle thing you need to move. not sure if i found it on here or audiworld but im sure if you SEARCH around you can find a few good install pictures
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Jun 04 2007
    Austin/DFW, TX
    bingo ^^
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    that looks like my pic! thats what i did best and easiest way
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    here is another pic, dont mind what im pointing at...
    Senior Member Two Rings audienthusiest's Avatar
    Apr 06 2008
    nada
    CALI
    i ran mine straight throught my ECU box it was a sinch.. and i think i used the fuse f5 ? not sure its one of the empty fuses... it turns on with the ignition... i like it that way cuz the gauge is always lit.... but thats just me
    May 12 2008
    Flagstaff AZ
    tap into the 75x relay, cant miss it, even has posts for terminals!!
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    B5 2.7t // GMT400 Tahoe
    Dallas, TX
    I'm about to install my vent gauge.. Tapping into the vent light sounds legit, right?
    Daily - 00' Audi S4 Quattro
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Mar 15 2007
    2001 A4
    seattle
    Quote Originally Posted by PiMPMAN101 View Post
    Yeah that's how I did mine that way it dims and all that when your lights are on
    Sep 28 2006
    Lexington
    I ran mine through the ecu box
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Aug 22 2008
    Central Maryland
    Did you guys have to remove the knee bolster or are there some ninja tactics to pull the wire straight up to the steering column?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by b5andm3 View Post
    You will have to anyways when you wire it up. But you have to feed it through there. Its only like 4 10mm bolts or something.
    My 5-Speed Swap DIY
    - B6 USP
