Results 1 to 10 of 10
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    Picked up f/r S4 brake setup, have a question..
    So after extensive research on what to go with and weighing options and keeping price in mind, I decided to go with S4 f/r setup. I picked up a set of front rotor/caliper/upright assembly and rear rotor/caliper assembly.
    Now when I came home and took a deeper look at it, I noticed that the wheel bearing on one front side is totally shot, broken. I am not sure what potential effect this has (I assume I can take my A4 bearings and put them in there?) but will this matter in my conversion?
    Thanks
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Re: Picked up f/r S4 brake setup, have a question..
    just go buy a new bearing and do it while your in there. you dont want to be swapping bearings from one car to another, not to mention they go bad often enough anyway. replace it while its all apart and save yourself the headache later.
    May 10 2004
    1.8tqms
    ghettlanta
    could the housing potentially be affected?
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    mmmm thats not ur wheel bearing
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    thats part of the outer CV joint haha :]
    if you look on the opposite side of that, there should be a bolt thats 19MM i think? (someone correct me if I'm wrong) and you'll need to break that loose, then that "bearing" you're thinking about will come right out.
    It's the CV and you can still see part of the CV Boot, haha.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Yeh thats part of the cv axle not your wheel bearing.
    Do you live in Atlanta?
    I have done this swap before so if you have any questions, I can probably answer them.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    May 10 2004
    1.8tqms
    ghettlanta
    haha being that i replaced cv booths before i should know better lol.
    anyway, do you think it's find to just transfer my CV joint (would it be the same part as the S4 one?) into the housing?
    Nov 02 2008
    Boulder & Seattle
    I presume it would be as you're not the first person doing this swap and I've never heard of people running into issues for the S4/A4 CV Threads not matching
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    May 10 2004
    1.8tqms
    ghettlanta
    All right guys I am on the brink on starting this work as my current front pads are GONE!
    First: To address geeky's post, I am running into two different arguments.
    I thought that the S4 hub housing itself was bigger. Therefore, a bigger wheel bearing (from a 2.8q or 01 1.8t) would be needed to fill that housing.
    So if I use the bigger wheel bearing, there's no way that my axle (MY2000) would fit into that bearing, right? That's why I'd need 2.8 axle.
    Somebody correct me if I'm wrong?
    Second: Let's say I'm getting 2.8q axles and tranny flanges. Good idea to swap drive axle seals, like these?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    You need the 2001 1.8t axles or any 98-01 2.8 A4 axles as they fit into the S4 hubs. Earlier 1.8t axles will not.
    Jim
    I Do Werk.
