Results 1 to 8 of 8
    Senior Member Three Rings A4 Dream's Avatar
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    Exclamation What does the 213 relay do? CAR WONT START!
    My car wont start!
    The only noise I get is from relay 213. It clicks ones pretty loud. Does this mean its bad? Would that relay cause my car not to start?
    It wont turn over. I have power to everything... my solenoid is fine and so is my starter.... it just one day didnt start.
    Any Ideas?
    Eibach prostreet-s coilovers, hotchkis sway bar front/rear, HID conversion, MAF attachment intake
    I have 2 sets of BBS LM REPS F/S PM ANY QUESTIONS
    Jan 25 2006
    A4 2.0T
    MD
    Re: What does the 213 relay do? CAR WONT START!
    A bad relay can cause starting failure. I don't know what relay "213" does specifically, but if its bad then replace it.
    Can you hear if your fuel pump is priming?
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    Quote Originally Posted by Don Supreme View Post
    no... there is nothing. No whining from the starter.. no clicking... nothing. The car does NOTHING when I turn it over... Relay 213 clicks. haha I dont have an owners manual... so im kind of stuck.
    Active Member Two Rings InfiniIV's Avatar
    Nov 17 2008
    2006 Imola Yellow S4
    Prince George, BC
    I had a quick look through the wiring section in the Bentley manual and I found 2 listings for relay 13, one was a starter lock relay and one was to do with the alarm and locks on tiptronic cars. I assume one is 13 on relay block 1 and one is on 2 however the maunal really doesn't say which is which. I think your question has already been answered though.
    Oct 06 2004
    Minnesota
    Sent you PM InfinitiV
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    Quote Originally Posted by InfiniIV View Post
    hmm so you think that the relay is a starter lock?
    My Positive battery wire was loose and bouncing around on the terminal... so Im thinking it fried the relay.
    Nov 17 2008
    Prince George, BC
    I would say its very possible its the relay, relays do burn out.
    I mean, lets look at it this way:
    Your car doesn't start
    You can hear a relay making more noise than it should
    There is a relay specifically for Starter Interlock
    All you have to do is pull the crap out from bottom of the dash and expose your fuse block, do whatever it is that makes the fuse make noise and if its 213 you have your answer. And since you already have a relay number I'd say you've already done all this so you most definately have a good starting point now.
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    haha yeah man. Im thinking Im just going to buy a realy. I have no reason not to. It clicks pretty loud... and its only about 20 bucks. Its just.. if that doesnt work.. I dont know what else to do. I might have to take it in and pay 400 bucks for them just to tell me whats wrong :/
