Originally Posted by
RAudi Driver
The dealer would take it apart for you under warranty when your cel light goes on and they determine that the gunk is the problem. However, like I said, I think that AOA wants them to start using this stuff instead of tearing the manifold off.
The last time I had my car at the shop for, you guessed it, DRC, I inquired about a misfire cel light. They told me the situation then and directed me to the parts counter to get some of this stuff. I probably could have had them pour it in for free but that would entail checking the car in for service.
Use 1 bottle every 1,000 miles or so, I would guess.
Gonna go pick up my RS from service, will ask about this stuff. As you say though... I really don't see how any additive can do a damn thing for the top of the valves though, the pics I have seen are horrible, and combustion occurs before these parts are touched and the detergents in the fuel can do anything. That is probably partly why they get like this in the first place.
When I was a dealership tech (for Toyota), we used to use this stuff called BG 44K as an OIL additive vs. a fuel additive. This is not like that Slick 50 crap, it is added as a stronger detergent, not to change the characteristics or viscosity of the oil. Did it work? I dunno, but a lot of the older mechanics swore by it. That also could have been because we got this little yellow plastic sprocket thing in the bottom of every can that we used in a customers car though, which could be collected and traded for tools and stuff :). I have to assume that there are some decent oil detergent additives / short term detergents available to deal with this kind of problem without taking the motor apart though... I just don't think that a fuel additive alone would be enough given the design of the 4.2 FSI.
Also, I rebuilt several 2.4 toyota motors for friends all with much higher than 100k mi on them (2.4 22r/22re was common in 80-90s toy trucks, great simple, solid, and durable motors, but timing chain was a weakness on them, single row chains if I remember correctly which would stretch and wear). One thing that I DID get to see myself... ATF was great at cleaning the motors. I don't know if it was bad for any components... but before I would do the rebuild I would pop off the oil fill cap (on top of the valve cover on the top front of the valve cover, with it off you can see alot) and look around inside and see obvious sludge and basically dirty, sludgy head. Then pour in a quart of ATF, run the motor for about 10-20 min (shop fan in front to to give radiator airflow of course), then look again and I swear it was MUCH cleaner, pretty neat. I did this at the urging of the old dog mechanics at the shop... I thought they were BSing me but NOPE. I should have known better, because when the shop ran out of Goop (awesome hand cleaner), ATF worked almost as good (and then normal soap and water got off the ATF, although after using the ATF just drying off with a shop rag was "good enough" for going to lunch anyway). I dunno if anyone has ever worked on a rear diff, but getting that used and sludgy, scummy, stinky 80-90w crap off of your hands is impossible with water, but with ATF (or Goop) comes right off! Even cleans under your fingernails without too much effort. The ATF in the motor was only meant to be a short term detergent (thins oil too much to lubricate motor correctly for long term use) NOT meant to drive the car around with it, but BG 44K didn't change the characteristics of the oil allowing it to be used for the life of the oil (and was much slower acting, so I doubt an experiment like what I did with the ATF would work).
Anyway, back to the point, it has been over 10 years since I was a line tech, so I will have to do some internet searching on oil additives (detergent type), etc. and see if something like that can cure this issue... cos I am not so sure about putting ATF in my RS :). 2.4 R is a completely different motor, and I don't remember it being exactly high revving either...
ANy experience here with that kind of stuff? BG 44K for example...?
