Results 1 to 10 of 10
    Veteran Member Three Rings CTUltrasport's Avatar
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    Re: Clunk noise when pulling away...
    Quote Originally Posted by MnTechnik View Post
    I dunno if I would call it a clunk but if i'm not mistaken there is an ABS check that the car does automatically after start up while pulling away that makes a little noise.
    can anyone shed further light on this? I am interested to know what this is and how it "should" sound.
    2013 Audi S4
    Mar 13 2006
    2002 A4 1.8TQM
    Columbus OH
    The first time you pull away from a stop after the cars been shut down for a bit, you'll here (and usually feel) an ultra-quick clunk. It usually happens in mine about 10 ft after I start rolling.
    It is simply the ABS pressurizing and doing a very quick self test.
    At first, I thought it was something in the driveshaft or driveline shuffling.
    If this clunk you all are talking about is only happening the first time you start to drive, this is what's going on, and it's perfectly normal. If this clunk is happening everytime you start from a stop (stop signs, red lights, whatever) then it's a different story.
    Upgraded the motor a little, brakes a little more, and suspension a lot.
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    I always thought that was my CV joints or my control arms. It always happens to me as well, only when the car has been off for over a couple hours, and it always happens within 5 seconds of the car being in motion. It also happens in my sister's b6, so I never wanted to believe it was something I needed to replace. Good to know.
