Results 1 to 5 of 5
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    bbk question involving matching a rotor
    Not sure if anyone can help, but I have boxster calipers that are going on my b5 a4 quattro with the purems adapter and lines that allow me to bolt it to the tt carrier and use the d2 rotor. Im looking at a set of rotors from ecs that are from their v2stg2 kit which are 332mm. now my question is, will the work with what I want? the d2's are 312 so the other rotors are slightly larger. Just curious if anybody can give me a direct answer.
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    Re: bbk question involving matching a rotor
    the carriers / brackets will most likely be for a specific size rotor. did you try calling mike at pure to ask?
    Jun 21 2007
    99.5 A4, 08 Mazda3
    I have not. I should though. Didn't think about it honestly
    Sep 22 2008
    sonoma, ca
    there's a valparaiso in IN? the one in chile is a rad town..
    Veteran Member Four Rings EBG 18T's Avatar
    Mar 27 2005
    The Cold North
    Quote Originally Posted by Tifun View Post
    the more you mix and match the more chances you have for issues coming up. Mike at Purems should be able to get you what you need. Most of ECS's rotors are subpar quality anyways.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
