Got a working used TB in there. Still will not even try to adapt, it just says "ERROR" on the Vag-com status box when I try. Tried both ECU's and the same thing happens.
I've cleared the codes several times, is there something else that could be stuck in the ecu's memory that I have to clear? When I clear the codes the only thing that comes up is 'Adaptation not Started."
