No, that code is an o2 sensor heater fault.
OXYGEN SENSOR TROUBLE CODES
There are two types of Oxygen Sensor trouble codes: O2 heater circuit codes and O2 sensor codes.
O2 Heater circuit related codes include P0036, P0037, P0038, P0042, P0043, P0044, P0050, P0051, P0052, P0056, P0057, P0058, P0062, P0063, P0064 & P0141.
O2 Sensor related codes include P0130, P0131. P0132. P0133, P0134, P0135, P0136, P0137, P0138, P0139, P0140, P0142, P0143, P0144, P0145, P0146, P0147, P0150, P0151, P0152, P0153, P0154, P0155, P0156, P0157, P0158, P0159, P0160, P0161, P0162, P0163, P0164, P0165, P0166 & P0167
The heater codes will set if a fault is detected in the O2 sensor heater circuit. The O2 sensor codes will be set if the O2 sensor readings remain low (lean), or high (rich), or do not change quickly enough, or do not change at all.
The O2 sensor reads unburned oxygen in the exhaust, and generates a voltage signal that is proportional to the amount of oxygen in the exhaust. The signal can vary from a low of about 0.1 volts up to a high of about 0.9 volts. A low voltage signal indicates a lean fuel mixture. A high voltage signal indicates a rich fuel mixture. The engine computer uses the O2 sensor's input to balance the fuel mixture during closed loop operation. A bad sensor may prevent the system from going into closed loop, and usually causes the fuel mixture to run rich causing an increase in fuel consumption and emissions.
A low voltage (lean) reading may indicate a bad O2 sensor, a vacuum leak, or a condition that allows unburned oxygen to enter the exhaust. Check intake vacuum at idle, and inspect vacuum hose connections. If okay, check for a misfiring cylinder, a burned exhaust valve that is leaking compression, or a leaky exhaust manifold gasket.
O2 sensor quick checks include watching the sensor's output voltage as the fuel mixture changes. Momentarily disconnecting a vacuum hose will cause a lean response from the O2 sensor. No change in the reading or a very sluggish response would indicate a bad O2 sensor.
NOTE: If you get an oxygen sensor code plus a random misfire code and a MAP sensor code, the engine probably has a serious vacuum leak.
