Sorry to revive this old thread.... did anyone find a solution to this problem, or is it just considered normal?
I have a CPO 2004 S4 with a manual, but even with it being under warranty, there is no way I am going to take it to the dealer and have them take 2 days to diagnosis it as "normal". Here are all the symptoms; I think they are all related:
1. CEL has come on and gone off twice in the past year (for about 2 days at a time). Both times, the dealer hasn't been able to do anything because the light went off by the time the dealer has seen it. Scanning the computer revealed a "lean condition", most likely caused by the MAF going bad (per the dealer).
2. When the motor is cold, the RPMs don't stick when I let out the clutch; they fall immediately and the shifts are smooth. When the motor heats up, then the RPMs hang when I let the clutch in for 1-2 seconds, especially at RPMs under 2.5k.
3. With a warm motor, the throttle response is bad (sort of like the engine is bogging). Shifts are impossible to get smooth- if I shift too fast, the RPMs are too high and the car surges when I let the clutch out. When I hit the unresponsive gas pedal, there is about a 0.5 second lag before the revs come up. So the shifts are basically like this- accelerate, clutch in, rpm's hang, next gear, clutch out, surge because the high rpm's, bog because of sluggish gas pedal, repeat. Not very fun to drive. Sometimes this bogging is worse than other times.
4. Sometimes if I take off from a slow roll in second gear (possibly other gears as well, but most obvious in second because of the steeper gear ratio), the motor feels like it is chugging to go from about 1k rpm until 2k rpm. After that, the motor runs smoothly.
5. Motor sometimes idles rough for about 2 seconds when sitting at a light. Revs drop by about 50 rpm, and the car shakes ever so slightly. Then the revs come back to normal and idles smoothly.
I am thinking this is a MAF problem. If something is going wrong with it, the problem will be most apparent when there is only small amounts of air flowing past it (which happens at very slight throttle openings). Maybe I am just trying to convince myself that this is the problem, but I can rationalize how every one of the problems above could be caused by a bad MAF. I am going to do the 55k service this weekend, and possibly change the MAF as well too see if the problem gets resolved.
Did anyone figure out what was going on with their own issues? Any remedies before I start replacing everything on the car?
