Results 1 to 9 of 9
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Drill sound comming from the air suspension after shutdown?
    Every once in awile after I shut the car off the suspension makes a mechanial notice which sort of sounds like a drill. It sounds like its supposed to happen and it stops after a few seconds but I was just wondering what it does that for?
    Veteran Member Four Rings HIstateS8's Avatar
    Feb 16 2005
    Aiea, Oahu, HI
    Re: Drill sound comming from the air suspension after shutdown?
    Maybe it's just your air cylinders leveling off?? I'd love to get an air ride set up for my car, the only thing that is stopping me is the dreaded air leak problem for aftermarket systems.
    -Brandon S.
    2002 Metallic Black //S8
    Nov 07 2008
    So California
    Does the sound come from the rear wheels? If so, its likely it the electronic parking brake cycling. Seems to do this after a certain number of locking the car.
    Jun 14 2007
    New York
    Quote Originally Posted by Galco View Post
    Does it matter if I use it or not? Because I never use the e-brake.
    Active Member Two Rings Adjuster's Avatar
    Jan 26 2009
    Boise Idaho
    I never use the e-brake either, but I have heard the sound.
    Figured it was just a compressor for the air shock system.
    Are the 04 and newer A8's like the old ones that use vacume to operate the door locks? I know my 98 has a pump in the trunk area that cycles from time to time to keep the door locks working. (Usually hear it after opening the trunk if the car has been sitting for a day or two.)
    Daily Driver 2004 A8L (With only 14k miles.)
    Replacing 1998 A8. (It's been a great car, just want a newer one without 136k+ on the clock.)
    Nov 07 2008
    So California
    Quote Originally Posted by Tiesto View Post
    No, it doesn't matter if you use the e-brake or not. The cycling is something the A8 does periodically. I'm not certain, but i bellieve its a safty percaution to prevent the system from binding up for those that rarely use e-brake; but that's just a guess on my part.
    The conclusion is that its normal for the e-brake to cycle. I believe it is decribed in the manual...
    Senior Member Two Rings DirtyJerzey's Avatar
    Feb 24 2008
    NJ-LA-TX
    That noise comes from the rear compressors. It actually is leveling the car out. If you ever heard that noise again stick your fingers in the wheelgap of you rear tire and fender and you"ll feel the rear leveling.
    Jul 04 2008
    2004 A8L l 2007 Q7 4.2
    Hudson, OH
    The noise is coming from the rear parking brake. It adjusts from time to time when you power off the car on D3s.
    Feb 24 2008
    NJ-LA-TX
    Well it's one of the two cause I feel the car adjusting it's level when that noise from the rear is appears
