Results 1 to 33 of 33
    Jul 26 2008
    Jersey
    Does anything (aftermarket) fit as good a RNS-E?
    Just exploring options before I drop 1K on a RNS-E.
    Does anything else fit just like an RNS-E?
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    Re: Does anything (aftermarket) fit as good a RNS-E?
    I've seen a lot of clean installs of the Pioneer Avic D3, which not only speaks for that headunit..but may indicate that Pioneer's newer lines (I believe it's an F-line now) may fit as nice/better.
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    AVIC D3 fits well, in part because it's one of the few that has red button lighting to match Audi interior styling. Here's a pic of it - however, I've heard this one is misleading with the matte-black look to the unit, but apparently the actual framing and material is a more glossy black.
    I know Pioneer is coming out with different/updated versions of the AVIC D3, but am too lazy to research it right now. I leave it to you, OP!
    Jul 26 2008
    Jersey
    Does it fit in though without any modification? I want to buy it, install it and be done. I'm not looking to hack stuff up with this car.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by spinny View Post
    If you don't want to mod at all, then the RNS-E is prob your best bet. Mine came stock and I'm really happy with it, if that helps.
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    That picture of the D3 is super photoshopped.
    Nothing will have the fit and finish of the RNS-E. The RNS-E will never have the tuning capabilities of some other head units though as well.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Quote Originally Posted by B7A4Sport View Post
    Yep, you're right, unless they changed it very recently.
    Here's a pic of the D3 in my old 350Z showing the actual finish...it's a glossy "piano" black look.
    The lighting of the buttons is infinitely adjustable though and should match the Audi dash just fine. The on screen controls can only be 7 or so colors though, one of which is red, so should be good there too.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    How clean the install is depends on the installer mostly
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Established Member Two Rings whoosh's Avatar
    Feb 07 2009
    Belfast, Maine
    What kit do you use for a clean install?
    Thanks
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    a good friend has the D3. neither he nor i can deal with it. by the time its powered up, youre already at your destination. takes forever. also, the touch screen is not very accurate or responsive and the delay between touching something and the resulting function is wayyy too long. it frustrates him to no end.
    i have the rns-e. i retro fitted it and would never dream of having anything else.
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Senior Member Two Rings TX-A4's Avatar
    Jan 23 2009
    '07 Titanium A4; '04 WJ; '13 F-250; ‘17 C2S 911
    TX
    Quote Originally Posted by A4CE1 View Post
    Wow, that's good to know; first hand experience is what one needs when looking for info on a subject like this. First time I've read negative feedback on the D3 though; I was seriously considering getting one over the RNS-E, but now I dunno.......
    2007 A4 2.0T-Q, S-Titanium, 6MT, Brilliant red; couple'a mods and a tenacious driver.
    Veteran Member Three Rings Spiff69's Avatar
    Nov 22 2008
    2021 Ultra Blue SQ5
    I love my RNS-E. MP3 playback, the navigation is solid. I wish it had a touchscreen sometimes and a higher resolution, but it is pretty well thought out. I would definitely recommend updating to the latest firmware if you end up getting one.
    DUH! an Audi
    los angeles, CA
    perfect fit would be oem, close to it matters what dash kit you get and who installs it. I am running a single dim and it doesnt look too bad, for what I need it for it does the job.
    OEM, lacks the certain capabilities, wattage output for speakers and expandability. I doubt most people go crazy on audio, so this might not be something you need.
    Jan 10 2007
    VA
    simply put, your friend has a bad unit. my d3 powers up before i leave the garage, touch screen is instant, i find no problems with its accuracy and i have large hands.
    the RNS-E looks better, but ANY aftermarket unit will perform and funtion much better.
    Dec 15 2008
    Golden, CO
    lack of touch screen and poor sound quality/output will keep me from buying an RNS-e
    the review above ^ about laggy response and sloppy touchscreen sensitivity, will keep me from buying a D3.
    now I don't know what to do :o
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    From a fitment standpoint, nothing fits as good as OEM. It's a drop in replacement designed specifically for the dash opening of your car. If functionality is a premium, however, there are many aftermarket units that can run circles around the RNS-E.
    Nov 22 2008
    2021 Ultra Blue SQ5
    Quote Originally Posted by ataylor View Post
    lack of touchscreen bugs me a little, but it's not a dealbreaker by any means. It is most missed on the phone screen, but I can always dial straight from the phone which is easier anyway.
    And honestly, if you're that concerned about sound quality you should be amping anything you put in anyway.
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    No matter how clean the install, I've never seen anything look as close to factory as the RNS-E does
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    DUH! an Audi
    los angeles, CA
    ^^that is very subjective.
    It just depends what the user wants for a system. OEM nav, looks great, but I just dont like it...
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    OEM is OEM, and it looks and works great too. If you want one I can probably get you it fyi. Good luck on the search
    Jan 17 2008
    07 A4 Qtip
    Alberta
    I used this one.
    http://cgi.ebay.ca/2002-2007-AUDI-A4...|39:1|240:1318
    It comes with the harness, adapters etc....*this way if you want to return back to stock, you don't have to cut any wires and it's painless*you will need to break the middle to make it double din. It actually fits flush in my car very nicely. I have a JVC double din touchscreen but all double dins are the same size, it's just a matter of finding the right harness to fit the A4. This is made specifically for the B7.
    It took me about 2 hours to install. On top of that, the B7 doesn't have an accessory light wire for the OEM deck so you have to tap into your fuse box. I have a wire that runs from the deck to my garage door opener fuse.
    So no it's not super easy and painless, but once it's installed..it's done!
    Quote Originally Posted by Sharkfin View Post
    Deactivated Two Rings
    Jan 02 2009
    SC
    I just got the F90BT installed recently. When you first get it to start up it takes a few minutes, but disabling certain features (such as checking your ipod for changes on every bootup), it's ready to go by the time I'm ready to drive away. It has features for ipod, bluetooth, dvd/xvid, xm/sirius, backup camera. Here's some photos I took with my phone.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    has anyone tried the Car Advanced player? i did some searches, but never found anything where someone has installed it in their car.
    http://www.caradvanced.com/products/...D-slot....html
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    If you let one review of the D3 from a guy who knows a guy with an obviously bad unit sway your opinion away from the D3, then you deserve to be confused.
    Go read other reviews from other sites. I have a D3 and I wouldn't trade it for the POS RNS-e at any price. Who cares if it's not an OEM perfect fit if you can make it fit and look like OEM. If you, personally, can't install very well then take the extra $400 or more you save when buying the D3 over the RNS-e and take it to a professional installer who will make it fit perfect and do all the wiring and shit for you.
    My touch screen works perfect, I have the updated 2008 NAV software, the latest OS, and it works perfect. Startup is less than 10 seconds, IPOD control is second to none, the Nav is pretty good for a DVD based unit, and the display is easy to read. On top of that, it can be integrated to the steering wheel controls and sounds better.
    BTW, i get compliments all the time on how it looks in the car and many people just assume it came with it (mostly non-enthusiast types.).
    That's not necessarily true. Not everyone has audiophile ears, but nearly everyone I know noticed a HUGE difference in sound quality from OEM to this head unit.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings Koby's Avatar
    Aug 05 2008
    Easton, PA
    Kenwood's new units use Garmin which kills Pioneer's horrid NAV software.
    Dec 15 2008
    Golden, CO
    Quote Originally Posted by davis449 View Post
    If I bought the D3, I would install it myself using a wiring harness made for the A4, and it would fit perfectly.. I'm not concerned about that. I would probably even matte-out the black finish for an OEM look.
    I do have an ear for good sound quality, I usually only listen to compressed audio at 256-320kbps, and a lot of uncompressed audio as well. I understand going w. the Pioneer is the best choice in this realm.. but I'm more concerned about the responsiveness of the unit, and the quality of the navigation. I didn't comment on the start-up time because I had read earlier about the POST and iPod check when the unit boots up, and how they're switchable on/off.
    Is your touch screen accurate/responsive? You're saying the user above has a dud? Thx for chiming in, I'm not completely ruling any thing out just yet
    Dec 15 2008
    Golden, CO
    Quote Originally Posted by Koby View Post
    Do you use a Kenwood double din nav/dvd player? Or could you recommend one you've seen in a B7?
    Feb 07 2009
    Belfast, Maine
    Great pictures of your setup........
    orbovi what mounting kit did you use? Thanks
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by p1nk50ck View Post
    That looks great. It flows well with the interior too:
    http://www.caradvanced.com/news/7/Au...ion-Guide.html
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    That caradvanced thing looks nice, but has anyone actually bought one? And can they get rid of all the spelling mistakes in the interface?
    -Tim
    Nov 22 2008
    2021 Ultra Blue SQ5
    RNS-E a POS? Come on. You may not prefer it, but it's not a piece of shit.
    Mar 05 2007
    San Antonio, Tx
    Trust me, the sound quality is just fine. If you were planning on going RNS-e with no speaker upgrades, then the AVIC is going to have 10 times better sound than OEM. Even if you were going to do some moderate upgrading, the AVIC would be fine to amp your new speakers off of. I didn't mean to make the user I quoted last sound like he was dead wrong. He's right, if you are shooting for excellent sound, you should have an amp in there too, but then again, you should change the head unit along with speaker and amplifier to get a better EQ to control your sound.
    Sounds like your compressed audio tastes are exactly like mine. I listen to mostly stuff in the 256-320 kbps range as well, though, admittedly, I don't liste to much uncompressed anymore due to the fact that I am space limited on my Ipod and refuse to carry around CD's in the car.
    As I stated before, my unit works really well and considering I got everything I needed (including installation parts) for under $900 a year ago, I'd say it's a bargain. My touch screen is very responsive. Took some getting used to because I'd never had a touchscreen in a car before this unit, but I love it now. Menu changes are fast and smooth.
    Apr 11 2008
    boston ma
    Does, rnse look better? maybe. Can it achieve the same functionality/upgradablility/sexy of an aftermarket unit? probably not. So tradeoffs will be made, I eventually settled for an aftermarket unit. And yes, I like the way it looks. See these posts for my pics:
    http://www.audizine.com/forum/showthread.php?t=259692
    more
    http://www.audizine.com/forum/showpo...1&postcount=49
