Results 1 to 16 of 16
    Senior Member Three Rings DrFeelGood's Avatar
    Jun 02 2007
    1997 2.8Q Audi A4
    Bamberg, Germany
    Have you changed your Transmission Fluid?
    Just brought the Transmission Filter from ESC Tuning and in the process of buying the fluid from the local Audi Dealership. DAm fluid costing 70 euro = $94.00. how much did you spend and what Fluid did you use? I readed that the Audi fluid is recommended. I also seen it somewhere on this forum.
    The dude from the dealership said it was no need to change the fluid. My car has 202, 000 Kilometers (126,000 miles). I aint feeling right for having new sparks plugs, changing oil and all the other shit and not changing the Transmission filter or fluid. It cant be good for the Transmission
    HAs anyone changed thier fluid yet? What do you suggest? I trust you dudes, Since signing up to this forum, i have got some really useful information.
    1997 Audi A4 2.8Q.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Have you changed your Transmission Fluid?
    I take it you're Tiptronic then?
    I've done numerous drain and refills on customer cars, it's pretty simple, but time consuming.
    I don't know where or who has a DIY for you to read, but I'll type one out if you really need it.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    it was a bit annoying. make sure u can open the fill plug before u drain fluid.
    car has to be on. and in order to fill, u need to put the car in gear and let it run forward and in reverse to completely fill the fluid. i got a friend with a lift because i was too nervous to do the process on jack stands.
    btw, my bolts were stripped on the pan, so it took a bit of elbow grease to get it off. i used the same pan, but got a new gasket. also, make sure to clean off the magnets in the pan. and use some de-greaser to clean it up well.
    edit: just realized that u have a 2.8, so i don't really know if everything is the same. you might want to double check my info first, but i can't really see it as being all the different.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    i would bring it to a dealer, the audi manual says you need to monitor the fluid temp with a program like vag-com while filling it (and doing what was suggested in the above posts) at the same time to get the proper levels. for me thats too many variables i dont want to deal with and would rather just pay some money and have it done right. you dont need to change trans fluid very often anyways. and yes the fluid is expensive and you cannot buy regular cheap A/T fluid.
    Dec 04 2007
    New York, NY
    Quote Originally Posted by ghost6303 View Post
    maybe im wrong but how would vag-com monitor the temp? There arent any sensors on the differential? At least on mine I dont and I have a 99 2.8
    Apr 01 2005
    one wagon one truck
    Michigan
    I've not yet but this summer I will be doing it. From the DIY I read it seems semi easy.
    Established Member Two Rings pologk04's Avatar
    Sep 12 2008
    2001 A4 2.8Q Sport
    South Pasadena, CA
    had mine done just a couple weeks ago. long story short, I drained the tranny on accident. it needs to be done right and it takes a special tool. on my 2001 2.8 the drain plug is the same as the fill plug and its on the bottom of the pan so you need a pump and reservoir to get the stuff into in there. I had my car towed to a local audi specialist and they charged me $17/liter (the dealer wanted $30/liter) the car actually shifts smoother now, even though they say that the Audi ATF lasts the lifetime of the car, its a good thing to do every now and then.
    2001 2.8Q Sport.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    I changed the fluid in mine and could tell a differnence. Its pretty easy too, but you need to buy the tool off of ecs to do it. I only use Royal Purple. I think it was 75w-90.
    Jun 02 2007
    1997 2.8Q Audi A4
    Bamberg, Germany
    I did my researh and seen this DIY http://www.blauparts.com/audi/audi_f...on_fluid.shtml. Well to be honest with you all, I wont be doing it. I am taking it to have a dude who specialize in Transmission. He doing it for me for 40 euro= around $60.00. I was going to have Audi Stealership do it but they wanted 350 euro= like $500-$600.00. He specailize in Audi and VW so i faith in him.
    Looking at the DIY... it looks simple but i know nothing is as easy as it looks.
    1997 Audi A4 2.8Q.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by jrock View Post
    That's for a manual trans. The OP doesn't have a M/T. He has a Tip/Auto, completely different process and fluid.
    Oct 02 2007
    Lone Tree, Colorado
    Ahh. He didnt put that at the top.
    Jun 02 2007
    1997 2.8Q Audi A4
    Bamberg, Germany
    Sorry fellas.. I Have a 1997 Audi A4 2.8 Quarttro.. automatic
    1997 Audi A4 2.8Q.
    Jun 02 2007
    1997 2.8Q Audi A4
    Bamberg, Germany
    The Spec. Number for the Audi Transmission Fluid seems to be equivalent to the Mobile Dex III Audi Automatic Transmission Fluid. Which one did you use ?
    1997 Audi A4 2.8Q.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    I changed my fluid and filter last year - it was easy. But, yes, the VAG is needed to be specific about the temp.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    I should really do this...
    Thanks for the reminder, probably call up eurotech as I'm to lazy in the winter, lol.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
