Results 1 to 7 of 7
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Flashing Traction Control after hard shift
    So two times now after going WOT in 1st(no launch) and shifting to continue WOT in 2nd, a flashing TC light briefly appears after the shift from 1st to 2nd. Both times I have needed to accelerate quickly into traffic since I usually don't otherwise go WOT in 1st, and the first time the car actually jolted and lost power like I dropped the clutch as if it went into limp mode. It returned to normal after I let off the gas and the TC light went away. The second time I saw the TC flash after shifting but I didn't feel a loss of power, however I thought I noticed a higher pitched whine from the turbo.
    The obvious answer would be that I somehow broke traction on the quick shift from 1st to 2nd but I doubt that's the case since I'm only running 15psi. Has anyone else experienced this problem? Mods in my sig, Clutch is Southbend Stg 3. Could this be related to slop from the stock motor or tranny mounts?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Flashing Traction Control after hard shift
    ESP was on and functioning?
    If so, you set off the traction control.
    -Doug
    Jun 01 2008
    Apopka, FL
    you don't have to break traction in the traditional sense to activate ESP. The power loss was probally ESP retarding engine timming.
    Veteran Member Four Rings SilverBullets's Avatar
    Dec 17 2008
    08 A4 Black, SLine, Ti; '12 GLI Autobahn (Wifey's whip)
    Columbus, OH
    For sure traction control working properly... theres 9 inches of snow on the ground and my car is doing that pretty much the entire time im driving... the computer sensed a tire slip, it took the power from the wheel and passed it to the opposing wheels
    Nov 09 2006
    02 A4 1.8TQM
    SF
    ^^ Should have mentioned this was on dry pavement both times. Maybe it's the snow tires that don't have the best dry traction. I'll have to try it again with my CO's(not like that would make a difference) and my summer wheels installed.
    Yes esp was on and functioning. Doug do you ever notice this with your BT setup?
    PS- I guess it's good to know my clutch isn't slipping
    Jun 30 2007
    Raleigh, NC
    you may not have "broken" traction completely - but you probably gave it enough of a jolt to set off TC. it happens - trust me.
    doug was saying the other day that if he flogs it in some gears even from a roll it'll set it off
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Damn well I guess I have to get to used to turning it off more often then. Is there any way to vag it and adjust the threshold or something?
