Results 1 to 12 of 12
Thread: limp mode
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Angry limp mode
    car keeps going into limp mode! it goes on and off like every 10 mins. I put the ECS N75 valve in and it was good for a while.Then it got back into limp mode again.. what else can it be??? reflash maybe??
    thankss
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    Re: limp mode
    cel?
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Re: limp mode
    yea but it for no cat conv
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: limp mode
    did you ever change your fpr? On an old gti of mine I did that...it was a bad idea
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Re: limp mode
    returnless fuel systems on b6
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Re: limp mode
    na never changed fpr i ran vagcomp on my car and i got a couple codes one for bad temp sensor thats y the temp gauge didnt work changed that now gauge works had another code for rear o2 sensor changed that and then i changed the n75 valve cause of limpmood...what eles can make it go into limp mood i was even getting on it when it went into limp mood after the n75 change
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: limp mode
    It could be the N75 from ecs, I have seen it to throw codes on B6 before, try a stock N75 (that you know is working), this may be the issue, and of course verify for vac leaks etc.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Re: limp mode
    well the valve is brand new it ha maybe 6 hrs in the car...and ur saying vacum leaks can cause limp mood to turn on?
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Re: limp mode
    could vacuum or boost leaks be a cause of limp mode?
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Re: limp mode
    got Vag?
    my car takes about 30 miles to get used to any intake/boost related modification... When I replaced my N75 (faulty) to a J valve, my car was only boosting 4psi for the first week, then it went back to 8. After my FMIC install... same deal. give it a day, or try removing the battery (make sure you know your radio code)
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Re: limp mode
    i dont know my radio code and audi askin 80 bucks to get it... damm
    Sep 14 2006
    Eagle Rock, LA, Ca
    Re: limp mode
    some radios do it, some don't. but if you want to chance it go ahead. My radio has never asked me for the code even after being unplugged for a couple weeks.
    my only other real suggestion is to check for leaks and find a Vag com user in your area... or you can get an ebay one which is good for reading/clearing codes
