Results 1 to 25 of 25
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    K04 Hybrid Updates?
    Just looking to hear how you guys that actually received good turbos from gpop are doing? Pros/cons lets here em
    Sep 28 2006
    Lexington
    Re: K04 Hybrid Updates?
    I wanted to know also, so I posted and this is what I got!
    Quote:
    Originally Posted by AudiTurbo View Post
    This turbo bigger then the gpopshop k03/k04?
    Yes, and it won't blow in 2 weeks or 65 miles etc.
    http://forums.vwvortex.com/zerothread?id=3429704
    http://www.audizine.com/forum/showth...light=gpopshop
    And you also get a manufacturers warranty, not a rebuilders warranty.
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Aug 16 2007
    Buffalo NY
    yes i would get the biggest one g pop has to offer which claims to be well within the 250-275hp range, not just a regular k04... I WILL NOT spend $1000 on a k04, i would spend $200 on a k03s and have 10hp less if thats the route i was shooting for
    Sep 28 2006
    Lexington
    How much bigger is the gpopshop one then the standard K04?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Aug 16 2007
    Buffalo NY
    you will have to contact them for exact specs
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    i don't understand why people even want to do k04's anymore. they are like almost 1000 bucks for just the turbo , when an eliminator is like 1300, and you will get MUCH more power out of it without changing internals or anything for that matter.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    In the long run a k04 is not nearly worth it. If you get it as cheap as a replacement k03 for a blown turbo i would say go for it but being that would never happen more then once in a blue moon, stick with the ko3s for much cheaper and almost the same results. If your going to spend that much go eliminator series....
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by SurferForever View Post
    x2 for the money k04's are the biggest waste, unless you think $1000+ for a turbo that makes 15-20chp more than the stock one is a good deal
    Aug 16 2007
    Buffalo NY
    GRRRR
    Please read what i am looking to do...
    A gpopshop upgraded k04 will produce 250-275 hp and will keep me under $600... I already agreed with the fact that a base k04 for $1000 is a waste
    Oct 28 2006
    Quote Originally Posted by slopoke View Post
    GRRRR
    hahaha 275hp out of a k04, i doubt it the 28rs elim is good for about 300-350chp and is twice the size. Dont waste 600 on a turbo that WILL blow up.
    Feb 27 2005
    North Wales, PA
    the elims actually start around 1500 for the hardware kit
    Sep 01 2005
    Quote Originally Posted by Poopie View Post
    gt2x eliminator hardware kit, $1295.00.... then they go up to 1595.00
    http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
    Feb 27 2005
    North Wales, PA
    well thats true, but no one really considers the gt2x as the elim turbos. usually elim is associated with the gtrs and the gt71rs
    Aug 16 2007
    Buffalo NY
    STRAIGHT OUT OF MAWHITEY'S SIG
    "SP51x OUTLAW Turbo @ 25Psi
    243 bhp @ 6415 / 275 torques @ 3370 Chipped UK Rules"
    Gpopshop does offer the sp51x upgrade, and i will more than happy with 240WHP, instant spool and a water cooled turbo
    Sep 01 2005
    243 bhp, is not even close to your supposed 240 WHP
    Feb 27 2005
    North Wales, PA
    243 bhp is less then 200whp
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Still slow....
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Aug 16 2007
    Buffalo NY
    oh then my bad i thought brake hp and wheel hp were initially the same
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    A standard K04-15 will make that much power and has with the J31 file.
    Even my stock K03 made more then 200whp which is over 250chp. So as you can see a hybrid K04 isn't actually needed.
    Common mistake. Its just hp made at the flywheel and usually on a engine dyno.
    Jan 10 2008
    98 a4 quattro
    New Jersey
    how did you do that with a k03
    Throttle pedal meet floor board
    K04 meet (pc16 + n75h)
    Honda's meet taillights (Im not a hater I had a integra)
    Jul 07 2004
    socal
    Quote Originally Posted by quatrroking View Post
    Custom tuning on 20psi for 104 octane. That is the setup that ran 14.29 at 97 mph.
    Sep 28 2006
    Lexington
    What is the biggest turbo for stock manifold though? Power difference and other differences in gt28r and gt28rs?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Sep 11 2007
    Dirty Jersey
    didn't that blow up?
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Jul 07 2004
    socal
    Quote Originally Posted by AudiTurbo View Post
    Elim is the largest turbo that can be mounted directly to the stock manifold. They make around 250-280awhp on pump gas and have even made up to 360awhp on race gas pushing 28-30psi.
    GT28r makes around 225-235awhp on pump gas.
    Sep 28 2006
    Lexington
    So what makes it differnt from the gt28rs?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
