Results 1 to 9 of 9
    Nov 26 2006
    Memphis, TN
    What Weight Oil to Use?
    I am going to change my oil this weekend but I am curious what weight everone is running. I live in Oxford, Mississippi and it never reall gets below about 30 degrees. What weight oil should I use?
    Thanks,
    Paul
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Re: What Weight Oil to Use?
    5W-40 is what I use. I live in Chicago... but I really didn't take that into consideration.
    Quote Originally Posted by OneFastBMW View Post
    Thanks,
    Paul
    0W-40 or 5W-40... Either one is good.
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Thanks,
    Paul
    This may help you...
    http://www.nordicgroup.us/oil.htm#Th...%20Mile%20Myth
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    this would be a better source...
    Any oil that has the VW502 00 and 505 01 approval will do.
    Standard Use around here is 5W-40 for Castrol Syntech or 0w-40 for Mobil1.
    http://www.audiusa.com/etc/medialib/....0023.File.pdf
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    Not to argue but my owner's manual said 0W-30 or 5W-30
    *shrug*
    Registered Member Two Rings
    Jan 26 2009
    Mid Atlantic
    I agree .............i have been adding a little bit of Mobil 1 5-30 to top it off.
    I guess i will switch over to a Castrol 5-40. I have had very good luck with this oil and will more than likely use this with the s4
    Senior Member Two Rings S4Berry's Avatar
    Mar 17 2008
    Tejas
    I'm in Texas and using Mobile 1 5W-30.
    * 2004 S4 - H&R Coilovers, 19" Bentley Continental GT Splits
    * 2200 lb EVO VIII (500 AWHP)
    Veteran Member Three Rings tatarin's Avatar
    Feb 11 2008
    05 B6 S4 Nogaro 6spd
    deerfield IL
    i use 0w-40 mobile1 and love it
