Results 1 to 11 of 11
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Another alignment after I slap my coils back on?
    Well recently due to recent events, I have put my stock suspension back on and I need to put the coils back. Prior to this, I had my coilovers on in perfect alignment. All I did was swap out the shock/springs but didnt change anything else. Drove on that for about a week alright. I now need to go back and put the coils on, they are going to go on with the exact same specs/height they had coming off. Do I need an alignment?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    Re: Another alignment after I slap my coils back on?
    I wouldnt think you would need an alignment as long as your coils are still set the same
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    If the suspension has been taken down, for any reason, even if you remeved the springs, then put the same springs back on the next day, the suspension geometry must be checked.
    You'd be surprised at how fine tolerances are.
    Oct 19 2007
    Dub State
    how far off would you estimate it could be?
    Jan 09 2008
    United Kingdom
    Quote Originally Posted by LowSantorin View Post
    You can't estimate, even if you mark things with paint before removal, which is why one should pay the maney to get it checked.
    Suspension alignment can go out over time, even if nothing is removed / replaced, an undulating road can cause the chassis to flex enough to bring about changes, even if the car's driven gently, and the driver didn't actually experience any harshness.
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Alignments are not that expensive. This was just talked about on another thread. If you don't get an alignment and if far enough off then you will go through tires more quickly.
    Jun 04 2007
    Austin/DFW, TX
    Last time I got an alignment was about 2 months ago. I have the CPP adjustable control arms,and I didnt adjust those in any way, so they are still in the same spec.
    My 5-Speed Swap DIY
    - B6 USP
    Jan 09 2008
    United Kingdom
    ^^^ Buddy, the fact you started this thread means you know deep down, it should be checked.
    I'd agree more with you if your reasons for not wanting it checked are financial, but since you say "they're still in the same spec", then I disagree.
    Good luck anyway.
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    Everytime you remove suspension, you should get alligned. Even if you remove the spring, coil for 1 min. go get it realligned.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Oct 19 2007
    Dub State
    I stand corrected, get it aligned!
    Jun 04 2007
    Austin/DFW, TX
    Well, I am going to get it aligned. I just had my subframe dropped for my new tranny. So that answers my questions.
    My 5-Speed Swap DIY
    - B6 USP
